Cases ANY CASE FOR LIQUID COOLING!!!! (DUAL LOOP)
Discussion in 'Hardware' started by Zomygodowned, 4 May 2009.
  1. Zomygodowned
    Zomygodowned What's a Dremel?
    29 Mar 2009
    Which case should i get for liquid cooling DUAL LOOP
    Haf
    Cosmos s
    Any others under $200 USD
    No tj07 please $$$
    Can fit or mount
    2 240 rads
    2 pumps
    2 res
    2 LOOPS
    External lc for one rad is fine too
    Don't just read sign up and suggest a case if you know of one
  2. docodine
    docodine killed a guy once
    10 Feb 2007
    Pretty much any full tower case? There's a thread going about the same topic right now, look around..
  3. RiverKairyn
    RiverKairyn The Cenobite Prototype
    13 Apr 2009
    As I said before the Lian Li PC-P8- Armorsuit is a fantastic case! & Is very watercooling friendly.
    If you have the budget for it then I would seriously go for it!
  4. Zomygodowned
    29 Mar 2009
    DUAL LOOP !!!!!!! P80 over budget
  5. Zomygodowned
    29 Mar 2009
    Budget is basically 200$ or 135 pounds or 155 euros
  6. Fisher.
    Fisher. partially impartial
    21 Jan 2009
    First off, WHY ARE YOU YELLING
    Secondly, If you're running dual loops, you are going to be dropping some serious $$ on WC stuffs as it is. I suggest dropping the dough on a higher-end, well built case (CM and Li-Li come to mind) and I can almost guarantee you'll be happier in the long run. From what I've heard, Stackers are very nice for throwing multiple large rads in. I have a Li-Li V2000b with 2 rads (one loop) currently and I'm getting a second loop and two more rads in the near future, but you have to be a bit more creative with rad placement.
    *edit* Ninja'd, but I stick by my guns.
  7. Zomygodowned
    29 Mar 2009
    Some people dont understand dual loop thats why
    How about the stacker 830 nvidia edition
  8. SiG
    SiG What's a Dremel?
    3 Dec 2007
    To reiterate what I have said in the past:
    Using the HAF 932 as your case of choice in a Dual-Watercooling (or any watercooling) situation isn't playing to the HAF's strengths, but ultimately it depends where your priorities lie in terms of performance -vs- aesthetics.
    As for the CM Stacker, save yourself a bit of extra cash by choosing a non-'special edition' case. Just as with Apple Macs, you're only really paying extra for the Logo.
  9. Zomygodowned
    29 Mar 2009
    Thanks but Im going to swap the 230mm side fan with 4 high speed 120mms
    Is the 830 better than the haf or cosmos s
    I need e-atx compatibility because im getting evga x58 classified
  10. Pardalu2
    Pardalu2 What's a Dremel?
    29 Apr 2009
    Hi,
    Why not try the acts 840 it's water cooling friendly too!! just more 45€ or 39GBP or 59US more....
  11. Unicorn
    25 Jul 2006
    I could get full dual loops into pretty much any full tower going at the moment using 240 rads... you don't start to experience problems until you try to mount 2x 360 rads in a case.
    Off the top of my head, I have fitted what you've specified above in the following:
    Antec P160
    Antec P182
    Antec 300
    Akasa Eclipse and Mirage (same case, different bezel)
    CM Stacker
    Silverstone TJ07
    CM Cosmos
    So many Lian Li's I can't begin to list them!
    You should have no problems finding a case to get that lot into m8y!
  12. Zomygodowned
    29 Mar 2009
    840 is above bugdet and looks horrible to me
    Second i dont like the antec p series
    Third 300 is a midtower
    Fourth lian li and tj07 are above budget
  13. Zomygodowned
    29 Mar 2009
    how is antecs 200mm rad for twelvehundred (i know theres no eatx support in 1200)
  14. bagman
    bagman Minimodder
    18 Apr 2009
    if i where you i would lok at the cooler master cosmos 1000 or S both very good cases or you could get the cooler master stacker
