Education Any chemists out there?
Discussion in 'General' started by Smilodon, 29 Oct 2011.
  1. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    Does anybody know of a chemical (or chemical process) that is able to etch away a tin/lead alloy (or a tin silver alloy) from copper without damaging the copper?
    I want to make a design on a copper sheet and was hoping to be able to cover the copper in tin and then etch the design back to the copper layer.
    The alternative process is cutting into the copper, filling with tin and then sanding everything flat again.
  2. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    from chopper? No idea mate :D Copper, well maybe somone else can chip in.
  3. Smilodon
    25 Mar 2003
    Oops! Fixed that now.
    I really shouldn't post right after getting out of bed...
  4. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Well since tin is a lot softer than copper I would think you could etch it away with acid and when you can see the copper where the acid is, you simply pour on water to neutralize the acid.
  5. mkb
    mkb Minimodder
    2 May 2010
    you'll want to pour on an alkali solution not just water to neutralise it. The water will simply dilute it and you'll still have an acidic sol. Something like Sodium Bicarb (Baking Soda) will be ideal and it's readily available.
  6. Jumeira_Johnny
    Jumeira_Johnny 16032 - High plains drifter
    13 Nov 2004
    I'm confused about what exactly you want to do. Can you perhaps describe it in more detail?
  7. RedFlames
    23 Apr 2009
    If I've understood it correctly... he wants to tin-plate some copper and etch a design into the tin, leaving the copper underneath untouched [or as untouched as possible]
  8. Jumeira_Johnny
    13 Nov 2004
    In that case: do the tin plating, coat the whole thing in wax, draw the design in the wax, clean the bare areas with acetone, and immerse the whole thing in an acid. Neutralise the acid, and remove the remaining wax.
  9. Smilodon
    25 Mar 2003
    I just realized that the etching plan won't work after all. I just can't get the tin plating even enough for the entire thing to polish out properly afterwards.
    If I were to do thing I think electroplating would be my best bet, but that's a bit too complicated for a weekend project.
    Time to whip out my Dremel, then. ;) :dremel:
    Oh, and for those still wondering: I'm just making a new pick guard for my guitar. It's going to be polished copper with "chrome" edges and maybe a logo. Tin seems to polish well enough to look chrome in small quantities. (Actually it's closer to nickel in color, but the hardware on my guitar seems to be a light nickel color so I think it will work well enough.)
