Windows Any decent software to draw a drilling pattern?
Discussion in 'Software' started by CrapBag, 22 Feb 2016.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I'm embarking on a little project with my daughter.
    She is greatly into fantasy things, game books etc.
    While on holiday she picked up 2 wood burning carvings, one for her friend and one for herself just to be used as wall hangings but I mentioned that they could look good as clocks so that's the path we are taking.
    I have ordered 2 clock mechanisms and purchased some brass upholstery tacks to act as number positions on the clocks but I want to be able to print out a fairly accurate pattern that I can overlay onto the wood so I can drill accurately.
    I want to pre drill the holes where using an undersized drill so that when I tap the tacks in the wood wont split, I will also add a dab of glue.
    So what free to use software is available to do this, I have dabbled with sketch up but to be honest I didn't find it very intuitive to use.
  2. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Anybody have any advice or software suggestions.
  3. jinq-sea
    15 Oct 2012
    To be honest - in terms of free stuff, all I could muster was sketchup. I've been giving this a bit of thought for you, and I've come to the conclusion that it might be easier to do it with a protractor and a piece of paper though, and a pair of compasses. Go old school.
    Mark out a circle from a centrepoint on a piece of paper the same size as you want the drill pattern to be on the face of the carving. Then it's as simple as making a mark (which for argument's sake can be the absolute top) and then working out the markings based on 360*/12
    That's what I'd do in the workshop if I didn't have Solidworks.
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    You don't need any calculations if you use a compass:
  5. jinq-sea
    15 Oct 2012
    Oh yeah! Just a pair of compasses then. Bosh.
  6. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    A big thank you to 13eightyfour for laser cutting me out a driiling pattern on card board it made it so much simpler to do this little project.
  7. Comrade Woody
    Comrade Woody Obsolete
    14 Mar 2011
    These came out great, good job :thumb:
