Planning Any good laser cutting company?
Discussion in 'Modding' started by Vognen, 6 May 2016.
  1. Vognen
    Vognen Minimodder
    2 Oct 2013
    I've designed myself a PC case, and the plan is to have it made in 2 mm aluminium. I've had a look on ebay, but alas, no luck with replies so far. Can anyone recommend me a company that does custom laser cutting? Doesn't matter if it's in Poland, Ukraine, UK or whatever :) It's just for initial planning, and to decide if I should continue with my plans
    Regards
  2. Nexxo
    23 Oct 2001
    I got my stuff done by The Laser Hive in the UK (see project in sig). They're helpful and prompt.
  3. Vognen
    Vognen Minimodder
    2 Oct 2013
    Thanks for letting me know. I'll send them a message tomorrow :thumb: Also just found out there's a place that lends out industrial equipments to students in my town, and they actually have a laser cutter. Cons are it can only handle 600x460 objects, and it can only cut acrylics. But if aluminium turns out to be too expensive it's nice to know there's a second option
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Laser Hive's Dave Chugg is great, He joined us in discussing the basics in converting the G5 case to ATX,
  5. cobalt6700
    cobalt6700 Minimodder
    17 Oct 2005
    My brother is a fabricator and has a laser, CNC folder etc. If you wanted to send me a drawing i'll get you a price :thumb:
  6. LePhuronn
    LePhuronn Minimodder
    6 Oct 2016
    I'd be interested in a couple of small things doing in 1.5mm aluminium if he can and doesn't cost the earth
  7. cobalt6700
    17 Oct 2005
    PM me over some drawings and I'll sort you a quote :thumb:
  8. LePhuronn
    6 Oct 2016
    Convo started :thumb:
