Any hint on EK Vardar 140 availability?
Discussion in 'Watercooling' started by IBMer, 11 Nov 2015.
  1. IBMer
    IBMer Minimodder
    5 Jun 2015
    Hi everyone,
    I am trying to sort out better cooling for my latest vintage mod project (http://forums.bit-tech.net/showthread.php?t=293459) and I was interested in EK Vardar F3-140ER.
    Unfortunately it seems that anything above the F1 is currently unavailable due to a flaw on early series.
    Does anyone have a hint on when higher rpm models will be back?
    I was planning to use 4x Vardar F3-140ER in push/pull on a very think 280 rad such as the Alphacool Monsta 280 (due to the nature of my project I am only using one rad for both CPU and GPU). Does anyone have alternative fans in mind (trying to get good static pressure + good rpm control through pwm)?
    Thanks in advance for the advice.
  2. Akira749
    Akira749 What's a Dremel?
    12 Jun 2014
    If all goes well, they should finally be available next week.
  3. IBMer
    IBMer Minimodder
    5 Jun 2015
    Thanks for the info!
