Motherboards Any P67 ITX Mobo's coming?
Discussion in 'Hardware' started by Parge, 25 May 2011.
  1. Parge
    16 Jul 2010
    I'm looking to reduce heat output in my ITX rig, so was thinking about a SB upgrade. However, I can't seem to find a single P67 (or even Z67) ITX mobo.
    Has anyone heard anything on this front?
  2. RedFlames
    23 Apr 2009
  3. jrs77
    jrs77 Modder
    17 Feb 2006
  4. Parge
    16 Jul 2010
    Yowza! Thats £172!
  5. Xtrafresh
    Xtrafresh It never hurts to help
    27 Dec 2007
    still though, ITX SB overclocking with mSATA slot for SSD caching and a full PCIe slot... nom nom!
  6. jrs77
    jrs77 Modder
    17 Feb 2006
    If you need this kind of power, yeah... sure...
    I'd still consider a full ATX board for overclocking in that case, especially because of the power-phases.
  7. Guest-16
    Guest-16 Guest
    mSATA SSD costs more than a normal 20GB SSD due to complexity and PCB, and they need to be bought in bulk: Intel NAND dept. will ALWAYS make their margins on it - esp. SLC.
    So it's just not fesable on mini-ITX unless you're pushing mSATA over lots of boards - even then, the market is extremely limited to prosumers who haven't already bought an SSD. Plus mini-ITX cases have SSD spots and if you're going to use space on the board for something you'd not choose mSATA sorry :)
    mini-ITX also doesnt have the capacity for high OC too - there's simply not enough space for VRMs and you'd have to use a 6-8 layer PCB = cost $$$$
    Plus I bet you want full DDR3 slots in addition to that full PCI-E slot and 6 SATA as well? :p:p:p
    I think that magic dust to make things bigger than they physically are would be put to much more profitable use in the pharmaceutical or porn industries :naughty: ;);););)
