Graphics Any R290 owners yet?
Discussion in 'Hardware' started by Neogumbercules, 10 Nov 2013.
  1. Pookie
    Pookie Illegitimi non carborundum
    4 May 2010
    I know the cables dont look that great but the PC is tucked under a desk and there is no side window. Besides it's only me that ever gets tolook at it :D
  2. Lassar
    Lassar Lean Mean Fighting Machine !
    16 Jun 2009
    Anyone had experience with Gigabyte Graphics Cards? Gigabyte 290 Back in stock at scan for £314. Spoke to scan regarding cooler removal. Essentially warranty would be void for cooler removal as with an MSI card... however...... as long as the card was not damaged by cooler removal scratched PCB etc and the original cooler reattached for returns should not be a problem if a fault arose. What you say? I have never watercooled that graphics card !!!! LOL
  3. dead beat
    dead beat Rippin six 4 life
    15 Feb 2009
    The blocks are very easy to fit. You'd have to be rather clumsy to actually damage the card.
  4. law99
    law99 Custom User Title
    24 Sep 2009
    spose it depends if there are any "warranty void if removed" stickers. I'd just go for it... check it works ok frist. With my 7950 I left it benchmarking on Unigine or whatever it is called for a couple of hours. Was ok when I got back so I assumed all was well then told myself I'd voided my warranty and boshed on the water block. Can't remember if there was any sticker saying here be dragons or of the likes.
    I guess if it died, I'd get pissy and send it back, original cooling attached, to see what happens. This is the *limited* risk you take. As long as you test it before jumping int that is.
  5. law99
    24 Sep 2009
    Woah there dead beat... you don't look so dead beat with 3 r290s... How's that working out?
  6. Lassar
    16 Jun 2009
    And its out of stock again....
  7. jinq-sea
    15 Oct 2012
    Haha my OCD prevents messy cables that can't be seen in my PC :)
  8. law99
    24 Sep 2009
    Ha ha... my messy cables are mostly unseen in my case. Doesn't mean it ain't messy... they are just unseen. (rumour has it if you venture to the other side of the case bulges can be seen... nothing a wall can't take care of)
  9. Lassar
    16 Jun 2009
    Everyone FYI !!! MSI R9 290 in stock at Ebuyer for £310 :D Just ordered mine.
  10. Shirty
    18 Apr 1982
    Linky? My internetting is failing me today.
  11. dead beat
    15 Feb 2009
    It's working out very well thanks. I'm getting great framerates in all my games. But due to the layout of the PCI-E slots on my board, the middle card is a bit snug. This means I've had to run a very aggressive fan profile, so the rig runs extremely loud. This is not really a problem because I'm currently gaming with my headphones. But the sooner I get some blocks on them the better....
  12. Lassar
    16 Jun 2009
    Hmmmm seems to have disappeared off the ebuyer website! Waiting for the email to say out of stock blah blah.
  13. Pookie
    4 May 2010
    Ebuyers mobile site is just awful! But I managed to see that they had an XFX model in stock.
  14. dead beat
    15 Feb 2009
  15. Pookie
    4 May 2010
    Well after 10 minutes of FarCry 3 my system completly crashed. Nothing in logs just a black screen and a horrible sound coming from the speakers. I didnt hear the fan spin up at all during the game so I guess it cooked itself?
    Control centre settigs are all on default and I havnt messed with any clocks. Idle temp is 44c which should be fine. Good job I still have my old card.
  16. jinq-sea
    15 Oct 2012
    Did you install the drivers from Guru3D?
    Oh, and did you do a driver sweep prior to the new install? :)
  17. Pookie
    4 May 2010
    I just downloaded the latest drivers from AMD's website. Looks like only beta drivers are available? Not sure if uninstalling the previous software removed the drivers from the 6970.
    On a good note I enabled the advanced section in ccc and reduced clock speed by 10%. I also upped the slider to 60%. Since then no black screen! Hardly a fix I know but it points to it being an overheating issue more than anything. I'm still in two minds with this card at the moment.
  18. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    So sorry hear pookie. Thank god I kept to the 7xxx series for now.
  19. Pookie
    4 May 2010
    With a little more tinkering I might have nailed it. I returned gpu to 100% and set target temp to 90c. I set max fan to 75% and hey presto no crashes. Noise isnt too bad either. Hopefully I panicked over nothing :worried:
  20. Lassar
    16 Jun 2009
    My 290 was delivered this morning. According to the Ebuyer website it's discontinued. I'm thinking it was a stock cock up advertising at that price. And they have quickly corrected It.
