Any recommendations for a usb external CD/DVD drive burner/Writer ? My DVD drive packed up on my laptop so i looking for a external one for around £30 ish, (Plextor PX-L890 SA Optical DVD Writer any good) Any recommendations & where is best to buy? Thanks for the help
The internal drive on a laptop is usually fairly easy to replace, and much more convenient than an external drive! Check in the manual, or just have a look underneath for a lever of some sort.
+1 for replacing over buying an external jobbie. Price will be similar, if not cheaper and far more practical. Although, you may have to undo a few screws on the bottom case to get access to your DVD drive.
