Cases Any suggestions please
Discussion in 'Hardware' started by chinleylass, 15 May 2010.
  1. chinleylass
    chinleylass What's a Dremel?
    15 May 2010
    Build list for new toy:-
    Asus M4A89TD Pro /usb3 motherboard, Phenom 2 x 4 965 black edition CPU, Titan Fenrir CPU cooler, Corsair HX 850 mod. PSU, XFX ATI Radion HD 5830 1024mb graphics card, 4 x 2Gb Corsair XMS3 DDR3 memory, Creative Sound Blaster X-Fi Xtreme PCIe sound card, Western Digital cavier black 1TB sata 3 64MB cache hard drive. Cannot decide on case. Fancy Fractal Define R2 -silver- or Lian Li PC A10A. Don't want an ugly black case!. Will it all fit? Bit concerned about lack of external bays in Fractal - quite fancied a fan controller and like the removable motherboard tray in the Lian Li. Any advice or opinions please.
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    Please will you edit your post to make it easier to read?!
    To be honest, if you're looking at spending £160 on a mobo, you should consider a P55 board and the i5 750 instead of the 965.
    I personally would avoid the 5830 and either downgrade to a 5770 or upgrade to a 5850.
    Do you really need a sound card? Onboard mobo sound is very good nowadays.
    As for the case, Lian-Li all the way!
    P.S. Welcome to the forums!
  3. EdwardTeach
    EdwardTeach What's a Dremel?
    3 May 2010
    Fractal is a nice looking case and very quiet - but you do need to buy a few extra fans.
    As previous poster suggested dot bother with the 5830. Either can a 5770 with a view to upgrading to 5770 crossfire in the future, or expand yur budget for a 5850.
  4. EdwardTeach
    3 May 2010
    Also do you really need and 850w psu for that spec?
  5. Sh0cKeR
    Sh0cKeR a=2(s-ut)/t²
    21 Aug 2009
    You could save £100 by dropping down to 4Gb of RAM, and buying either an HD5850 ( you could push to a 5870 perhaps ), or an i5 750 and a decent P55 motherboard. I would also switch the Caviar Black for a Samsung Spinpoint F3, as thats easily the best mechanical drive.
