Other Any 'vapers' out there?
Discussion in 'General' started by Sentinel-R1, 13 May 2013.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    I'd say all flavourings come with unknown risk, for absolute safety just vape PG or VG without any flavours, it's just not as enjoyable, I think it's the flavour concentrates that cause the most concern for vapers, capella brought some v2's but don't taste as good.
    But if I went that far I may as well just cold turkey, been vaping long enough to get me off smoking so maybe it's time I bought a big stash of lollipops & chewing gum & go Kojak style. :D
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
  3. Otis1337
    Otis1337 aka - Ripp3r
    28 Nov 2007
    Anyone interested in buying this?
    Got it new off amazon after seeing it in a shop been really impressed with its looks and spec's but totally forgot the reason i stopped vaping was because i cannot taste anything from them anymore. Like a permanent vape tong.
    There £50 online and about £60 in the shops.
    Iv used it for about 2 hours, 0.5 coil is wicked with mothers milk (with little use, its still new really or can be binned if you think its ickky to use it), and tried out the RBA. 1.5 coil is untouched.
    As its only had 2 hours use its as new/mint.
    Would come with a Genuine Efest Purple 18650 2500mAh 35A IMR High Drain battery.
    Its basically a Rev3 subtank mini which is redesigned and a new kbox mini 50w with variable wattage.
    The coils are kangers Rev3 vertical occ coils.
    Asking £45 inc.
    On market place:
    http://forums.bit-tech.net/showthread.php?p=3858137#post3858137
  4. mrlongbeard
    31 Jan 2010
  5. docodine
    docodine killed a guy once
    10 Feb 2007
    how'd you guys enjoy vapefest?
  6. mrlongbeard
    31 Jan 2010
    Disappointing, it was my first and last.
  7. jrs77
    jrs77 Modder
    17 Feb 2006
  8. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    Bought myself a white Subox and I'm back on the vaping train (pun intended) after a relapse of about 6 months.
    Gotta say I'm impressed, technology has come on a lot in 6 months, there were no temp controlled mods when I was last looking at gear.
    Also just bought a £24.95 mixed box of e liquids from Vape a Box, will see how it goes and if its decent will subscribe.
    Giving up the death sticks is never easy but vaping does make it somewhat bearable.
  9. Panomama
    Panomama I once signed up on uniform dating
    11 Jul 2009
    I bought:
    A doge v2x
    100ft 28g ni200
    mvp 3 pro for work
    Anml Looper 30ml
    Nick's blissful brews - fro yo 30ml
    Element pink lemonade 20ml x2
    Kraken - Crystal menth 10ml
    Kraken - Squid Ink 10ml
    Kraken - Nana State 10ml
    Beer.
  10. InSanCen
    InSanCen Buckling Spring Fetishist
    30 Mar 2005
    So many pretentious ****nuggets.
    I didn't need any reason to say no when my bored 7yr old wanted to leave, before 10:30 on Saturday. Got what I wanted to, but was distinctly disappointed by the attitude of an awful lot of people there.
  11. Shirty
    18 Apr 1982
    The true commercialisation of vaping has now been completed. Long gone are the days where a bunch of enthusiasts can get together, events like these are just dominated by "consumers" in the truest sense of the word.
  12. Waynio
    Waynio Relaxing
    20 Aug 2009
    Recipe I've been vaping the past month, it's 2 bottles mixed 50/50.
    1st bottle.
    10% vanilla custard
    5% butter
    2.5% caramel
    2.5% french vanilla
    2nd bottle
    10% banana cream
    10% french vanilla creme
    Mixed 50/50 is awesome, it's like a top notch custard but without the vapours tongue.
    edit-
    Made a 2nd batch of it changing the 2nd bottle recipe to.
    10% banana cream
    10% vanilla bean ice cream
    It's even better & was only bottled 2 days ago so should be even nicer by the time I get onto it, 2 to 3 months.
    After seeing the subtank mini RBA plus that Shirty posted it got me curious to try it out so drilled my regular RBA chimney base on both sides & every hit is perfect.
  13. shindead
    shindead What's a Dremel?
    14 Aug 2014
  14. Shirty
    18 Apr 1982
    What atomiser/build are you planning to use?
  15. shindead
    14 Aug 2014
    I have no idea.... I want something that will last and produce a decent amount of vapor. I have numerous kangertech tanks and they have been shocking.
  16. Shirty
    18 Apr 1982
    Are you budget limited at all? I found a really good budget combo was the iStick 20 or 30W and a good atomiser like the Lemo Drop gives an incredible amount of vapour for the cash. However I mainly use high power box mods and RDAs now so things might have moved on a bit.
    Eleaf stuff is pretty good and wallet-friendly though.
  17. [PUNK] crompers
    20 May 2008
    Have you looked at the Evic vt kit? supposed to be good for the money and you get temp control if that interests you
  18. shindead
    14 Aug 2014
    I'll be buying two (one for me one for the partner) so I dont want to break the bank..... the battery im not tooo bothered about as they are all roughly the same. its the heads i have ALWAYS had problems with. Leaking seems to be the most common problem.
  19. mrlongbeard
    31 Jan 2010
    No, no, no, no.
    You seriously need to check the lowest resistance atty they'll fire.
    If you go for a subtank, then the MVP you listed will simply refuse to work as it'll only fire 1 Ohm or above, however if you go mech mod or unregulated you could end up dying in a horrible fire ball when your battery goes pear shape.
  20. shindead
    14 Aug 2014
    why is this so complicated? :p I just want to quit smoking and have a lot of vapor :( Ill be going into Grey Haze to buy them so if I have a rough idea of whats good from you guys they can advise further? I just dont want to be conned :p
