Other Any 'vapers' out there?
Discussion in 'General' started by Sentinel-R1, 13 May 2013.
  1. Spanky
    Spanky Multimodder
    14 Apr 2010
    Ah nice. Might try that Red Astare concentrate. I have a couple premium Red Astaires in the box and one on the desk at work , also a Black Astaire which is ... meh ok. I have some premium Hiesenberg in the premium box still from Mortons Mystical Mix. Its pretty on point but i do fancy having a go at making my own!
    This is my point .. i must have a good 2 litres of premium juice still to smoke ... or get rid of. Learning to start making my own has been quite fun so far.
  2. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Flavours in rotation for me are,
    Red Astaire
    Biscuit Boss
    Fried Cream Cakes
    Strawberry
    Blue Slush
    Bunce
    Smakers
    High Voltage
    Red Oil
    Cool Mint
    Jungle Juice
    Cinnamon Coffee
    Cinnamon Danish.
  3. adidan
    25 Mar 2009
    Coming up to 5 years off the cigs, El Toro Cigarillos NET juice has been my go to. Tried others, they never take with me.
    Bit pricey but cheaper than the baccy was.
  4. Vault-Tec
    30 Aug 2015
    Has any one re-skinned a battery before? it's easy, right?
    Basically my beloved Tesla Invader III is a bit naughty, and if you are not careful it damages the battery wrapping. So I have ordered some new ones (very cheap) was just a little concerned over what is underneath and possibly shorting something and causing RAWR.
  5. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge. Software Dev @ Corsair Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    General advice is don’t. Just spend the money to get new ones
  6. Vault-Tec
    30 Aug 2015
    They are new. That's the kicker. And they are Fogstar and weren't cheap.
  7. MLyons
    3 Mar 2017
    As someone that has blown a battery deliberately in a fairly controlled environment and nearly blown one alongside my hand and face accidentally, just buy new ones. I promise you it’s a hell of an lot scarier in person than any video you’ve seen.
  8. Shirty
    18 Apr 1982
    It's a 20 second job per cell. Just look on YouTube. I've done it dozens of times without issue.
    Sentinel-R1 and Vault-Tec like this.
  9. Byron C
    Byron C AKA “Sticky Equilibrium” on weekends
    12 Apr 2002
    As long as the cell casing isn't damaged and there's no foreign bits of metal present that could potentially cause a short, then wrap 'em in gaffer tape for all it matters.
    The battery chemistry is highly dangerous, but as long as the cells themselves aren't damaged then I can't see any potential problems in just changing the thin outer plastic casing.
    Vault-Tec likes this.
  10. Vault-Tec
    30 Aug 2015
    When I looked in the Fogstar box earlier and it actually includes two new wraps. So yeah will give him a go :)
  11. Sentinel-R1
    Sentinel-R1 Chaircrew
    13 Oct 2010
    Couldn't disagree more. In fact, rewrapping your cells at the first sign of wear to the outer skin is highly recommended by battery specialists.
  12. MLyons
    3 Mar 2017
    Really. I was always under the impression they advised against it due to the risks of someone blowing themselves up.
  13. Sentinel-R1
    13 Oct 2010
    No, not at all. Your cells could be a matter of days old when you damage the plastic wrap, so the cell chemistry is still perfectly healthy but the chance of shorting the terminals would be significant unless you re-wrap it. Once re-wrapped, you're as good as (if not better than) new, as the aftermarket wraps tend to be more durable and of a higher quality.
  14. silk186
    silk186 Derp
    1 Dec 2014
    It's not hard, get the battery wraps and use a blow dryer. In vaping forums, it is very common to do, especially with mechanical mods because
    1. you are recommended to use an external charger so lots of wear
    2. they recommend re-wrap the slightest sign of damage
    PS. remove all jewellery, especially rings
  15. Vault-Tec
    30 Aug 2015
    I don't wear any but thanks for the heads up man. I'm not in a ring/chain phase right now and rings only get in my way.
    Good idea on the blower. I was going to use a heat gun with no temp control. LOL, that could have been fun :D I do have a hair dryer here though that my ex didn't want. She threw it out, but I paid £45 for it (Nicky Clarke very heavy and high end). So I kept it. I use it now to cure spray paint :)
  16. Sentinel-R1
    13 Oct 2010
    NOT a heat gun, unless you want a prosthetic. Hair dryer on medium heat is fine. No more than a few seconds in the heat at a time. Couple of seconds in, couple out. Rinse and repeat until the battery is snug.
    Make sure you don't lose the little washer on the + end of the cell when you unwrap it. You'll need to reuse them, unless your new skins come with replacements. Try not to over-wrap either end of the cell when you rewrap it. It can cause problems with the fatter terminals inside some mods.
  17. silk186
    silk186 Derp
    1 Dec 2014
    I've seen a couple of photos of some massive blisters. It's really easy, just take your time and make sure the battery doesn't touch an metal and make a circuit. Unwrap and rewrap one before you start on the next.
    Watch a few vids on youtube and go for it.
  18. Vault-Tec
    30 Aug 2015
    My fogstars came with some free pink wraps and reinforced O shaped bits you put under the wraps for the bottom. I would bet is is for mods that are hard on the batteries.
    I've bought ten of these from China, just waiting on them to come in :)
  19. Sentinel-R1
    13 Oct 2010
    The O shaped bits are for the top mate, the positive end - they stop anything getting between the positive button top and the negative casing. There shouldn't be anything on the negative end, apart from a small amount of wrap.
  20. Vault-Tec
    30 Aug 2015
    Brill, thanks. I wish companies wouldn't just assume you know everything and told you what they actually were and how to friggin' use 'em !
