Other Any 'vapers' out there?
Discussion in 'General' started by Sentinel-R1, 13 May 2013.
  1. The_Crapman
    5 Dec 2011
    I think it will definitely be a "for home use only" item :hehe:
  2. The_Crapman
    5 Dec 2011
    Now with 50% more ridiculousness :hehe:
    I did not anticipate the mouthpiece being that long, which now makes the pipe unbalanced and refuses to stand of it's own accord with the tip pointing down as it should be, but an improvement on the original for sure.
    Shirty and Byron C like this.
  3. m0o0oeh
    m0o0oeh Modder
    20 Dec 2006
    I *need* one of these things!
    The_Crapman likes this.
  4. The_Crapman
    5 Dec 2011
    I've ended up putting a voopoo uforce x nano tank on it, as the taste I was getting off the stock one wasn't great, wasn't sure at first as was a flavour I'd not used before, but a clean and fresh coil with a known entity confirmed it was in fact the device that was a bit off. Very happy now tooting away to my lungs content
    adidan likes this.
  5. mrlongbeard
    mrlongbeard Multimodder
    31 Jan 2010
    Well shite, I'm vaping again.
    Failed when on holiday, sitting around outside for extended periods just felt wrong, so off I went and bought a quick not disposable thinking I could vape for the week and then knock it on the head again, except I failed to appreciate that jumping back in at 10mg was going to be a akin to quitting smoking all over again :waah: and has left me a right grumpy A-hole.
    So quick order in today at vape club for some batteries, atties and VG, and time to mix up some 5mg when it arrives with a plan to be back down to 1mg and quitting again at the end of the year.
  6. The_Crapman
    5 Dec 2011
    The old "well, it is a holiday. I am meant to enjoy and relax as much as possible...." is probably the reason I have had to quit smoking so many times :hehe:
    mrlongbeard likes this.
  7. trueno!
    trueno! That's TRUE-N-NO if ure not sure!..
    24 Apr 2009
    Dropping nicotine strength is what worked for me too, but the habit was way harder to shake off than the actual nicotine itself. I got to a point where I was only vaping with my morning coffee, but found my hands just needed to be busy through the day. Fidget cubes and chewing gum helped a bit, but there were definitely a lot of moments where I was really tempted to pick it back up, especially during stressful days. If you ever decide to return or just want a solid device for backup, I had a really good experience with pods from geek vape. They’ve always been reliable and pretty simple to use, so maybe worth a look if you’re downsizing gear.
  8. mrlongbeard
    31 Jan 2010
    Or the beginning of November as it has come to pass, my fidget toys are taking a hammering.
    Arboreal likes this.
