Education Any wood working people out there?
Discussion in 'General' started by Boscoe, 28 Apr 2019.
  1. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    Hi all, I'm going to be making a server rack out of plywood by stacking CNC cut pieces together to form the profile. I like the aesthetic of this and it'll match my speakers. The process of the stacking takes quite a while, for the rack it'll take about a couple of hours and so I'm looking for advice on long term curing wood glues. I need to move the pieces around for the full two hours. When I did my speakers I stacked 12 sheets using Titebond III and unfortunately had to deal with some misalignment as the first sheets stuck together before I could finish the stack. I don't think PVA will last long enough. Anyone know what I should use/where to look?
    Thanks
  2. Yaka
    Yaka Modder
    26 Jun 2005
    Titebond III is the best there for wood. they do a a liquid version called hide glue which has around about an hour or so work time https://www.axminster.co.uk/titebond-liquid-hide-glue-ax22595
    i dont think there is any alternatives perhaps maybe from 2-part epoxys with a long cure time but the mess/clean and some cases fumes means its not worth it going down that road. but from what you are saying you will be breaking/moving the contact points? if so the bond will be weak.
    might i ask what exactly are you building that would need some movement before fully curing?
  3. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Second Titebond III as very good wood glue. Had a good look and I think you are unlikely to find any glue that will give 2 hours to keep adjusting.
  4. Mister_Tad
    27 Dec 2002
    Titebond III a go-go.
    If anyone says otherwise, they're simply incorrect.
    Over-size and trim if you can't guarantee you'll get it right on first-set
  5. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    Titebond is my go to for all wood related projects, as has been suggested finding a wood glue that has a 2hr+ working time isn't going to be easy, can you not pin the various layers together with thin gauge nails/pins or screws? the hole will be covered by the next layer leaving only the final one that needs to be aligned perfectly before clamping it? I made a table top (similar to the laminated ply tables you can buy from untothislast) a while ago using that method and it worked out fine, much easier than dealing with a massive glue-up.
  6. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Can you add holes for dowels at the CNC stage? It'll make alignment a breeze (perhaps, I don't have a complete mental picture of what you're doing).
    As an aside, I always use PVA. It smells of childhood and gets a plenty good bite. Also, dirt cheap.
  7. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    I'm gonna vote for titebond hide glue. Great open time and stronger than PVA.
  8. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Alignment dowels, and 50 million clamps.
    Mr_Mistoffelees likes this.
  9. wolfticket
    19 Apr 2008
    If you're CNC-ing each piece could you include two holes accurately positioned on each layer for alignment/keying? That way to could have a vertical through piece/pin either for accurate alignment, either permanently or just for construction.
