Motherboards Anybody familiar with AI Suite II ?
Discussion in 'Hardware' started by modd1uk, 19 Dec 2011.
  1. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    When AI Suite II is installed on my FM1 media pc/file server videos will randomly stop streaming, almost as if the HDD or the ethernet is going to sleep, i cant find any settings in it (i may be being completely blind).
    I know its the cause of the problem because if i remove AI Suite II from the PC media streams perfect, no cutting out at all, anybody any advice, got me stumped this.
  2. The Protocol
    The Protocol What's a Dremel?
    6 Sep 2011
    Just Asus software being itself, never use their utilities unless you have to, which is likely the case here (don't know any other software with fan control). Just set your fans to somewhere you're happy then delete AI Suite, the settings should remain in the BIOS - really hate AI suite. It randomly works fine or is chaos depending on the install
  3. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Yeah the fans are set in the bios, the whole computer is silent i love it. Dont need ai suite installed then ?
  4. Kernel
    Kernel Likes cheese
    29 Sep 2003
    I had the AI Suite running on this board, I think I deleted the whole package 15 mins after installing it...
  5. AoE
    AoE What's a Dremel?
    4 Oct 2011
    AI Suite is not good at all, especially the over clocking software.......well in my experience of it anyway
  6. Big Elf
    23 Apr 2009
    The one piece of the AI Suite I really like is Fan Xpert. I use it for PWM control of my pumps and it works extremely well. Although you can use the BIOS for basic control Fan Xpert gives a lot more flexibility.
  7. modd1uk
    modd1uk Multimodder
    4 Sep 2006
    Is there something in ai suite that would put the lan to sleep ? Cause its streaming fine with it removed.
  8. Big Elf
    23 Apr 2009
    Not that I can think of. Check Device Manager though for Power Management settings on your network devices. Also check the 'Magic Packet' settings in the Advanced tab for the network adapters also in Device Manager although they tend to wake the system up rather than put it to sleep.
    Edit: Just remembered that AI Suite installs ACPI Management for 'AI Nap' which can really bu**er up your sleep settings. However I know next to nothing about that.
