Graphics Anybody tried either of these budget 560s?
Discussion in 'Hardware' started by murraynt, 14 Jun 2011.
  1. murraynt
    murraynt Modder
    6 Jun 2009
  2. Pete J
    Pete J Employed scum
    28 Sep 2009
    Not that I've tried them, but Asus and MSI are perfectly well known brands!
  3. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    I wouldn't call Asus or MSI budget cards?
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
  5. Ph4ZeD
    22 Jul 2009
  6. Parge
    16 Jul 2010
    True, but is far more powerful! I'd definitely go with the 5870!
  7. KidMod-Southpaw
    28 Sep 2010
    I agree, the price has dropped a lot since the 5870's came out and they're still a very respectable card in terms of power and temps, one of the best behaved cards you can get.
  8. murraynt
    murraynt Modder
    6 Jun 2009
    The reason I called the budget was because they were the cheapest of the 560s :)
    I forgot all about the 5870. I'm still unsure.
  9. Pete J
    28 Sep 2009
    I'd look at the BT review of the 560. The 5870 seems to be an equal, and as Ph4ZeD said, the 560 will overclock far further.
    Heh, and to think I started looking at the 560 Ti results!
  10. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    If you can get one at a good price a GTX460 may also be worth a look. Fundamentally it is identical to the GTX560 but you may be able to save yourself £20 and not really lose anything in the process*.
    *The GTX560 *may* overclock further but it isn't guaranteed as the GTX460 already overclocks well.
    Another comparison (well as close as I can get) to pad out Bit's rather Anaemic results:
    HD5870 vs GTX560Ti
    Rather mixed bag here although remember this is against a GTX560TI not a GTX560. Games that don't heavily favour Nvidia seems to be slightly faster on the HD5870 (Crysis, BFBC2, Metro) although in the end the results could be called a wash.
  11. murraynt
    murraynt Modder
    6 Jun 2009
    Thanks for that xaser. I don't think I would go for a 460 as it is to close to the 275 in performance.
  12. BLUEHORSESTUDIOS
    BLUEHORSESTUDIOS I haven't lost a finger yet!
    19 Apr 2010
    I'm running two 560ti in sli and can max out all settings within COD and amazing results.
  13. xaser04
    27 Jun 2008
    At the same clocks a GTX460 and a GTX560 will perform exactly the same. Only the lower stock clocks on the GTX460 make it look slower.
    Oddly though since I last checked GTX460 pricing has slowly crept up whilst GTX560 pricing has slowly dropped. There is only around £10 in it now which means it makes more sense to get the quicker-out-of-the-box GTX560 than the GTX460.
  14. Guest-16
    Guest-16 Guest
    But.. but... SUPER ALLOY POWER and racing stripes!!11o1o1neoneone
    :rock::rock::rock:
    It's a fully upgraded power hardware and heatsink!
    You know you want it.
    Plus we've got a GPU Tweak for all cards (not just ROG) launching next month :rock:
  15. Parge
    16 Jul 2010
    ...... that vents all the heat straight into your case.
  16. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    What, to replace that complete heap of **** that is Smart Doctor? Also, please make all your cards voltage control compatible with Afterburner. I know it's a competitor's product, but it's where it is because it's the best. I refer to the 6850 Direct CU. V1 was compatible, yet the V2 wasn't, which made voltage tweaking a complete pain in the arse.
  17. murraynt
    murraynt Modder
    6 Jun 2009
  18. murraynt
    murraynt Modder
    6 Jun 2009
    A bit of an explanation aswell guys.
    I am upgrading my screen very soon but i don''t think my 275 will handle 1920 x 1080 very well.
    I will either get a new gfx with the screen or else get new SSD and wait for the 6xx series and 7xxx series.
    Thanks for all the replies guys.
    BT always shines through.
  19. Fingers66
    30 Apr 2010
    In that case wait until you upgrade your screen. New GPU's will probably be out by then.
  20. Guest-16
    Guest-16 Guest
    Yea Smart Doctor is finally being dumped. Apparently it's about 8 years old.
    GPU Tweak should be better than Afterburner once we're done. That's the spec the designers have otherwise I'll go upstairs and start throwing chairs. It'll work across all our cards and if you run SLI/CF/PhysX/Multi-GPU you can change each card individually too.
