Hi there I installed anyDVD yesterday so I could watch HD-DVDs on XP however after the install I rebooted and I got a install screen for AnyDVD and evry time I reboot it pops up again and I cant work out how to get rid of it. It’s not listed as a start-up item, any idias? Cheers wavefront PS: I can find it in the task manager though is there a way I can find where the .exe is stored? Iv tried searching the windows folders with no luck
Try this click start>run>type"msconfig">go into boot > see if you can find it in there and uncheck the box>restart ...or download ccleaner then go into the start up menu and uncheck it in there..If you cant find it anywhere else go into programe files and see if it's in there, if you don't need it anymore you can then delete from there
