Modding Anyone ever seen Spray on glass paint?
Discussion in 'Modding' started by RiPz, 15 Dec 2004.
  1. RiPz
    RiPz What's a Dremel?
    12 Dec 2004
    Glass paint is pretty transparent... and paints on smooth surfaces pretty well.... i was thinking...
    this might give a pretty nice anodized looking efect is applied evenly to a peice of metal... then clearcoated, would be pretty touch too.... problem being.. i've only EVER seen glass paint as a brush on material... anyone else ever seen spray on glass paint... or can think of another alternative ?.. something that wont make the metal dull, but add colour to it.. still being able to see the texture of the metal clearly...
    Any ideas ?
    \\RiPz//
  2. Yerg2k
    Yerg2k What's a Dremel?
    7 Dec 2004
    Maybe this is what you're looking for... I used crystal clear enamel for my radiator enclosure. It is clear, but adds a gloss to any bare metal. I'm not sure that it will dullen the metal, and it certainly doesn't colorize it any. Still, it looks nice with paint underneath.
  3. Shrapnill
    Shrapnill What's a Dremel?
    5 May 2002
    I would imagine the biggest problem (if youre doing REAL annodized alum) would be adhesion. Aluminum requires special etching prior to painting.
    However, a clear enamel seems to be what youre looking for, or if you want something think- a resin would give you a great coating and set up super smooth.
  4. voodoo2k4
    voodoo2k4 Ghetto Modder
    21 Apr 2004
    Yes you can buy spray glass paints that are just like spray on stained glass and will adhere to mirror flat (mirrors if you want too) surfaces.
    I used to work in a craft shop and sold them. Got a can of blue here infact, made by odds n ends i think. U know the people.
    Deano.
  5. voodoo2k4
    21 Apr 2004
