Modding Anyone got a good place to get spray paints?
Discussion in 'Modding' started by Cadillac Ferd, 2 Mar 2006.
  1. Cadillac Ferd
    Cadillac Ferd What's a Dremel?
    11 Oct 2005
    Hey all, I was just wondering if you guys out there could share what brand of paint you guys use for your mod projects also where a good place to find spray paint online would be. I recently used some krylon paint when I was modding my xbox but I really wasn't too happy about the way the colors turned out.
  2. tecguy
    tecguy What's a Dremel?
    27 Feb 2006
    i've heard monster paint is alright?
  3. Nexxo
    23 Oct 2001
    I would go to a professional car paint shop, see what colours they are using at the time and if you see one you like, ask if they will spray your case with the left-over paint. Normally the remainder is wasted anyway in the process of emptying and cleaning the spray gun, and they won't mind doing a small case at the end of a big car job.
  4. tecguy
    27 Feb 2006
    Thats a good thing but then if they say no or charge you a tenner you mite as well have bought spray paint,the best place to go is a car shop and get some of there car paint if your case is metal but remeber to get some primer and clear coat to go on before and after,but if it aint metal don't use car paint because it won't look as good because cars are made of metal and so are metal cases so you see the connection!! :rock: :rock: :rock: :D :D :D
  5. Nexxo
    23 Oct 2001
    A tenner is a bargain for a professional spray paint job --I'd gladly fork over five times that.
    There are several "how-to's" about case painting on this forum. It does indeed rewquire sanding, a primer, more sanding inbetween paint layers and a protective top coat.
  6. Cadillac Ferd
    11 Oct 2005
    Cool cool, no idea where I can find a car shop that would do that also I wanted to do the painting myself as I have to paint a whole bunch of little things after I disassemble my 360 in addition to my computer case thing. Any ideas as to what band of spray paint would be good for the metal of my case and/or the plastic of my 360 case?
  7. Ab$olut
    Ab$olut What's a Dremel?
    22 Dec 2004
    Thanks for the idea think I will go ask around and get them to phone me when they have sprayed a red car :hehe:
  8. Dngrsone
    Dngrsone What's a Dremel?
    17 Feb 2005
    Use vinyl dye for the plastic-- it penetrates and actually colors the material instead of lying on top, so all the etching and such is as sharp as ever... it looks as if the plastic was molded in that color.
    You can get vinyl dyes online or at car parts stores. You'll have to make several passes to get good coverage when spraying it.
  9. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    That gives me an idea to take a computer over to my friend's work, he mods cars for a living, including one that has appeared on a recent edition of Max Power. Might be able to get a professional job done as I'm planning another mod with phase cooling :naughty:
    In answer to the thread, I used a £6 can of plasticote on my test rig (after applying primer) and it has a really good finish. However if you did it professionally such as in a modding garage, you could get a finish as good as a car's finish (as others in this thread have already pointed out).
  10. sk8phreak88
    sk8phreak88 Minimodder
    8 Aug 2004
    I'm sorry, but don't listen to this guy.. It's just fine as long as you do all the prep work. For example, here is an xbox case that I painted with House of Kolor.
    House of Kolor is a professional car paint, but it works just fine on many other surfaces.
  11. metarinka
    metarinka What's a Dremel?
    9 Feb 2003
    what you can ultimately paint on and how strong it will look is usually determined by the prep work (which is like %99 of the work). Some plastics and rubbers like urethanes and ABS IIRC won't normally hold colors. there are plastic primers that will bond to the plastic and plastic etchers that will rough up the surface for prep. vinyl dye will work well on most plastics but not on metal so color matching can be a pain. I would try asking body shops usually the guys are friendly. I asked my schools body shop and the students gladly laid down paint for class credit. IF you prep and prime the piece most places will spray for a marginal or free cost and will generally get better results
