Other Anyone had really impacted wisdom teeth out with LOCAL anaesthetic?
Discussion in 'General' started by oscy, 11 Jan 2020.
  1. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Here, they'll take them if they even look like they'll be a problem.
    I didn't get the choice for my last oral surgery. It was general as they had to remove bone, muscle and nerve. They simply couldn't have done what they needed under local. Now I have no teeth at all, and fitting for dentures has been interesting, so far. I go back tomorrow for another fitting. Trying to fit where my jaw was broken has been difficult.
    Good, you took things how I wanted them to be taken. All I want for you is a painless procedure and fast healing. I think it'll be done better under general, but after my experience I'm a bit biased.
    Fast fact, watch your stitches if you have them. Mine burst after two days and the healing after that was ugly and painful. They stitched it too tight and I had a whole mouth dry socket for a month. That was misery. Thankfully they killed a fair few nerves (between that and the necrotic infection) so it wasn't as bad as it could have been.
  2. oscy
    oscy Modder
    22 Sep 2011
    My pre-op got rearranged from next week to next month now. How long does it take afterwards for the actual surgery to happen? 'Cause I wonder if I'd decided local if it'd be getting done quicker.
  3. Guest-44638
    Guest-44638 Guest
    Pre-op to op is usually a week... well; it was when I had my Functional Endoscopic Sinus Surgery done.
  4. jinq-sea
    15 Oct 2012
    I had a seriously impacted one done under local. It was fine. I had it done privately.
  5. Parge
    16 Jul 2010
    I've got two laterally impacted wisdom teeth in my lower jaw. That means they poke inwards. The dentist has advised that I try to avoid ever having them out because it will be a nightmare of a surgery - but if I do, she says it will 100% be general.
    Go with whatever the experts say mate.
  6. veato
    veato I should be working
    15 Jan 2010
    I had an impacted wisdom tooth out. It was a local so I had the pleasure of being wide awake. I don't know exactly what they did but there was some cutting of bone involved and I still have some root in there that couldn't come out.
  7. LennyRhys
    LennyRhys Oink!
    16 May 2011
    I had a rotten molar removed under local, and it required part of my jaw to be drilled away (for access). This happened twice, and the surgery lasted around 50 mins each time. It was hell, and the worst part was the slow and painful recovery afterwards. Knowing what I now know, I'd never volunteer to have that done under local anaesthetic again!
  8. Ferino
    Ferino Minimodder
    26 Mar 2010
    Had all four out under general in november. Two lower were badly impacted. Was under less than an hour and home by lunch. Painful for a week after wards but avoided dry socket thankfully. The effects of a mostly liquid diet with little fibre (doh) were actually worse!
  9. d_stilgar
    d_stilgar Old School Modder
    11 Feb 2010
    I had mine out by local anesthetic. It was totally fine. I actually prefer it that way.
  10. oscy
    oscy Modder
    22 Sep 2011
    I made a Freedom Of Information request, because I'd rather be wrong and corrected than assume.
    So I asked for the number of deaths, long-term complications or life-threatening incidents (eg. anaphylaxis, heart attack, cardiac arrest) suffered during surgery with the general anaesthetic being a direct cause.
    I asked for just the 4 Oxford University hospitals (I think only 2 have surgery anyway) and a time period of 2007 (when the main hospital had a big revamp) to 2020. Not needlessly long, but no so short that the answer would just be 0... right?
    The reply has come back: 200 instances.
    In just the last 2 years.
    I think local will do me fine thanks. :dremel::D (artist's impression)
    They couldn't do the full timeframe because there were so many. But I can change the parameters and timeframe if someone else wants a certain stat, like maybe just deaths in the last year.
  11. Gareth Halfacree
    4 Dec 2007
    Out of how many operations? If it's 200 out of 400, then sure, be cautious. If it's 200 out of 200,000,000, then that's a different kettle of fish.
    I've had... five operations under general anaesthesia in my life, and I'm still here. If I need another, I ain't going to worry about it. If either of my daughters needed general anaesthesia, I wouldn't hesitate.
    EDIT:
    Also, if you wouldn't mind breaking down those stats a bit:
    • How many of the 200 were deaths?
    • How many of the 200 were life-changing?
    • What is the age breakdown for those 200 events?
    • How many of those 200 were elective generals, rather than "we put you under and swap out your heart/lungs/whatever or you definitely die?"
    • An extension of the above: how many of the deaths had a terminal diagnosis without general-exclusive surgery?
  12. Mr_Mistoffelees
    Mr_Mistoffelees The Rotary Cat.
    26 Aug 2014
    Out of how many operations conducted under a general in that time?
    Guest-44638 likes this.
  13. oscy
    oscy Modder
    22 Sep 2011
    There's no stats like that because to fully investigate a request, it has to take max 18 hours, but it takes 20 minutes per record. Looking at the past 2 years (the "easily accessible" part) would've taken 66 hours alone.
    They could only tell me that at a glance there were 200 "relevant records" but obviously it's too much of an undertaking to look in detail. They suggested I request looking up just deaths over a much-reduced timeframe, but that's no interest to me.
    As for how many operations, apparently there's just under 3,000,000 general anaesthetic operations done in the UK per year, and there are 2000 hospitals. So we could be bad mathematicians and take all these rough numbers, then you get 3.3% (1 in 30) in my hospitals potentially involving anaesthetic-related 'serious incidents'.
    I don't trust them anyway. The hospital's known for it's ****-ups unfortunately. I was confident we'd be fine from the coronavirus until it was reported a patient was being treated there. And what do you know, it's somehow already ended up in a prison 10 miles from the hospital. No one's surprised!
  14. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Feels like you need a whole load more context before you can start drawing conclusions based on a number of 200 in isolation.
  15. Mister_Tad
    27 Dec 2002
    Out of every single time I've had a general, I've died exactly zero times.
    Widening the sample group five-fold to include my immediate family, still zero.
    So according to my data, there's a 0% chance of complications.
    Statistics a-go-go!
    I had an operation under a regional nerve block 6 weeks ago that necessitated four injections deep in my armpit and another three in my elbow, with lots of ultrasound-guided wiggling of the needle to boot. I was wishing I had asked for a general right about then.
  16. Xir
    Xir Modder
    26 Apr 2006
    I've had one removed under local….I'll never forget the sound of it breaking while still attached in my life.
  17. oscy
    oscy Modder
    22 Sep 2011
    It's awesome. :D
