Modding anyone know anything about this case
Discussion in 'Modding' started by fathazza, 24 Jun 2002.
  1. fathazza
    fathazza Freed on Probation
    20 May 2002
  2. sboy
    sboy What's a Dremel?
    6 May 2002
    for the extra £15 get a lian li pc60 then your sure to know its gonna be a top made case, rather than a cheap clone!!!
  3. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    i'm pretty sure thats a rebadged skyhawk case.
  4. fathazza
    20 May 2002
    but this one comes with a 400W psu too which makes it like 50 quid cheaper!
    are the skhawk cases decent or budget pieces of turd l?
    thx
    hazza
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    reminds me of the avgs cases:
  6. cderalow
    cderalow bondage master!
    23 Jan 2002
    sure is.... one of the guys i work with bought one of these... rebadged skyhawk... its basically a standard atx mid tower only made of aluminum.... as someone else said... you'd be better off spending the extra amount and getting a LL
  7. memizex
    memizex What's a Dremel?
    24 Jun 2002
    heh, im getting a case thats very similar to that one. I thought its one hell of a buy. The thing is pick out a case that fits you, dont listen to what people say. If you like the case go for it. I mean, i have seen so many cases and case mods put onto lian li cases thats its becoming rather boring to look at them. I know they are good cases but the whole purpose to case modding in my opinion is to make it match your style and to be creative. If you choose the lian li is for you anyway, then go for it man.
    (V)emizex
  8. sboy
    6 May 2002
    You have a point mate but if i was gonna pay at least £100 for a case id like to know that its made of the highest quality, which correct me if im wrong on this but a alui case with 400w psu for £100 there must be a few things structualy wrong and lets face it its bound to be cheap as :D
  9. UnLoadeD
    2 Jan 2002
    I didnt mean to say it was a bad case, just coz its a skyhawk, i was just pointing you towards them so you could maybe find some more info about it.
    http://www.skyhawkusa.com/
  10. hexa-db
    hexa-db What's a Dremel?
    2 Apr 2002
    It looks like an aluminium IceMaster to me..
