Modding Anyone know where I can get 60mm M4 bolts?
Discussion in 'Modding' started by couzo, 5 Feb 2003.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I am making a 120mm shroud and putting this on my radiator and need some 60mm M4 bolts (No nuts just bolts) any ideas where Icould get some from tried the local hardware stores but they only go up to 50mm??
    Thanks
  2. george_seamons
    george_seamons What's a Dremel?
    27 Nov 2002
    I know this doesn't answer your question, but I also want my question answered, can you name anywhere that I can get 70mm M3 bolts? I need them for my Thermaltake Smart fan on the Alpha Pal8045, because the fan only has holes on the top. Its hard to explain, but the fan shroud is only held on by blu tack at the moment :worried: I too tried at several hardware stores, and they only went up to 50mm :(
  3. couzo
    26 Apr 2002
    I know what you mean if i come across anything i will let you know its like :wallbash: at the mo trying to find them!!
  4. kiwi-x
    kiwi-x What's a Dremel?
    16 Jan 2003
    i don't know if this exists where you are, but near my home there is a specialty nut and bolt store... the only thing they sell are fasteners (??spelling)
  5. chambochae
    chambochae What's a Dremel?
    11 Nov 2002
  6. couzo
    26 Apr 2002
    thanks for trying chambo but i need m4 ones due to them going through 2 fans (1 is a shroud) then partly in to my black ice radiator!!! Why oh why do m4's only seem to go up to 50mm!!!:wallbash:
  7. Pug
    Pug What's a Heatsink?
    16 May 2002
    How about threaded bar with nuts on?
    Think they have it at B&Q too, IIRC.
  8. couzo
    26 Apr 2002
    can you buy from them pug?
  9. Nexxo
    23 Oct 2001
    Inox Fasteners are da man! You can internet-shop practially any conceivable size nut and bolt from them, in stainless steel, polished if required, in any number, for as little as 30p a piece.
    I have used them; they are quick, reliable and do an excellent product. They are my mainstay for all my modding related fastener needs. And yes, they do M4 x 60mm hex bolts.
  10. couzo
    26 Apr 2002
    Nexxo I can only see ones that go up to 50mm? Can you show me a link to the ones you mean??
  11. couzo
    26 Apr 2002
    WOW!!! just found them they are perfect I could kiss you...........er but i won't!!!:eeek:
  12. Nexxo
    23 Oct 2001
    Hey, I'm secure in my masculinity... :D ...but no tongue, OK? :p
    Anyway, I'm glad I could help.
    Yessiree, Inox Fasteners do kicking stuff! See some of their M4 x 40mm bolts in the pic below...
  13. couzo
    26 Apr 2002
    Where did you get those black washers from? Are they rubber?
  14. DETN8R
    DETN8R What's a Dremel?
    27 Oct 2001
    anyone know of a US distributor like that?
  15. Dazbo666
    Dazbo666 What's a Dremel?
    16 Dec 2002
    If you're in the UK, either ask at B&Q, or preferably at a local hardware store,
    or online, try Screwfix??
  16. Nexxo
    23 Oct 2001
    @ Dazbo666: Screwfix has an extremely limited choice. Inox Fasteners mentioned above really are the best for anything fastening related. They even do self-locking nuts (sounds painful, but they're actually really useful).
    @ Couzo: the rubber grommets at the front of the picture are originally meant to protect wires that lead through holes in metal casings. As such you can neatly pop them in fan mounting holes. You get them at Maplins or any electronics store, in various sizes. The rubber rings at the back can be mail-ordered from PC Modifications or in the UK from Kustom PCs.
  17. couzo
    26 Apr 2002
    nexxo I rang inox and the guy was great but he told me they don't make m4 bolts at 60mm and when i told him about the website saying they were listed he said a different guy is incharge of that and they have had problems like this before so he is making some custom ones for me!!:rock:
  18. Nexxo
    23 Oct 2001
    That is great news! I have not actually talked to them on the phone before, but if they can custom make you some, perhaps they can do some M3x120 ones to allow me to mount fan, shroud and BIX radiator in one assembly!
    Hmmm... I see possibilities! :naughty:
  19. couzo
    26 Apr 2002
    You can always try the guy I spoke to was really really good knew what he was talking about and I can't reccommend him enough
