Cases Anyone own a Corsair 500r?..
Discussion in 'Hardware' started by Chriz, 20 May 2015.
  1. Chriz
    Chriz What's a Dremel?
    18 May 2015
    Hello all,
    Could anyone take measurements of the top panel mesh from the 500r? Unfortunately Corsair don't list many details on their spares page.
    Very much appreciated,
    Chris
  2. Cabe6403
    Cabe6403 Supreme Commander
    3 Apr 2007
    Have you tried emailing them? Seems like something they could supply if you ask nicely
  3. Chriz
    18 May 2015
    I wasn't sure if that would be a bit to specific to ask them? I thought asking here would yield better results as I know there are plenty of varying case owners and modders on bT.
    I'll drop them a line anyway and update here if anything comes back.
    Cheers,
    Chris
  4. Digerati
    Digerati Minimodder
    19 Feb 2011
    If wondering what size fans it supports up top, I would say the same as the front panel - so 2 x 120mm for sure since that is what it comes with up front. But the specs also say it supports 6 120/140mm fans. So you may be able to put 140s up there. And the docs do say 240mm radiator.
  5. GeorgeK
    18 Sep 2010
    Some companies are excellent at replying to questions like that - personally I've had excellent responses from Seasonic and EVGA so you might get what you want with an email :thumb:
