Well, I have a black vinyl sticker and I want to put it on my case. However, i also want to paint the black so it blends with the sticker. My question is if i paint over the edges of the sticker the same time I paint the case will the sticker and case blend seamlessly or will the edge of the sticker be visible??? Thanks in advance!!!
think it will depend on how many coats u put on, but i think u will need a fair few coats to make it seamless
I would imagine the edges would be very visible. I had a truck that had pin stripes on the side. When I took it to get it painted the paint shop left the pinstripes on and painted over them. It was very obvious that they were there. So they re-did the painting. Perhaps if you spread a very thin layer of bondo or something first and then sanded it smooth at the same height as the sticker.
one option would be to take a razor and cut the design on the sticker and throw away the black area and just stick the actual image to the case... did that with a sticker on my guitar... square black sticker w/ staic-x logo looked crappy on my blue guitar, so i trimmed around the design and stuck it on my guitar.
