Modding Anyone painted a cheiftech case and the front?
Discussion in 'Modding' started by couzo, 29 Dec 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I am going to be painting my cheiftech dragon case and was wondering how people removed the clear bits of plastic from the door that go over the power and hd leds as they seem to be glued in. Did you just cover them up?
  2. Linkitch
    Linkitch What's a Dremel?
    11 May 2002
    I painted mine.. and i just pelled the glue off... the glue was very weak... and you really don't need paint on them, they stick on fine...
  3. cderalow
    cderalow bondage master!
    23 Jan 2002
    yeah... just take a screw driver and push them out from the front... then paint away... depending on what color you're going to paint it, you might want to think about vinyl dye for the plastic bits. :idea:
