Cases Anyone use/used one of these?
Discussion in 'Hardware' started by TheRealShep, 26 Mar 2011.
  1. TheRealShep
    TheRealShep ssSSSsssssssSSSSSSSSSsss
    14 Mar 2011
  2. Marvin-HHGTTG
    Marvin-HHGTTG CTRL + SHIFT + ESC
    10 Oct 2010
    I guess it depends on what you want to use it for, but I wouldn't suggest it for a gaming build, due to the single PCI slot, and of course the 200W PSU. Though that might be changeable with one of Silverstone's SFX PSUs. However, the PSU is so close to the mobo, I doubt you'd get much of a CPU cooler on there. I think it's really Atom or Zacate at most.
    Source - Thermaltake's page
  3. TheRealShep
    14 Mar 2011
    Maybe I should stick with the SG02
    Dan
  4. GeorgeStorm
    16 Dec 2008
    I'm looking at the SG05 for my mitx LAN build.
  5. Marvin-HHGTTG
    10 Oct 2010
    This, did a build in one myself, and still can't get over how small it is. Good amount of space for decent size GPUs, and something like a Scythe Shuriken will go in there nicely.
  6. GeorgeStorm
    16 Dec 2008
    Planning on using a H70, but yeah, should be good, looking forward to it, really annoyed I missed it on Scan today only a couple of days ago.
  7. TheRealShep
    14 Mar 2011
    Yeah I am putting an i3 with GTX460 in one in the next month so hopefully I should have a project log going (got a few case mods planned too)
    Im making a highly portable gaming rig because of having to travel back and forth a lot.
    What pictures have you got of yours? I would be interested to see the inside to look at space.
    Dan
  8. TheRealShep
    14 Mar 2011
    I was thinking about putting one of those in when funds allowed but didnt know if it would fit.
    How much cooler does it run with one do you know?
    Dan
  9. Marvin-HHGTTG
    10 Oct 2010
    I haven't taken any pics I'm afraid, it was built for a uni mate who needed/wanted a small PC (as the rooms are small and he's used to a laptop). Got a 5770, an i3 530 and an Intel X25V in there, plus an old laptop HDD he had for data - runs great, and as most parts were sourced 2nd hand, it cost about £320 to build including W7.
  10. TheRealShep
    14 Mar 2011
    Yeah mine is about £400 with reused parts.
    Dan
  11. docodine
    docodine killed a guy once
    10 Feb 2007
  12. Silent_Raider
    Silent_Raider What's a Dremel?
    20 Aug 2010
    My H70 runs 27 C idle and 33 C max in the rig in my sig (didn't mean to rhyme that). I did replace the stock fans with 2 x COOLER MASTER Excalibur R4-EXBB-20PK-R0 120mm Case Fan. But I run them at 60% power, otherwise they sound like an airplane. When I was running them at max I think I had 25 C idle and 30 C max.
