Hi, I am trying to find the DNS servers for AOL (UK) as i am tring to set up static ip address's for my computers to enable port fowarding, any ideas where i can find these?
Welcome Be sure to search before creating a thread. You could have found the addresses quite easily using Google...
Or you may just be able to set the DNS server on the computer to the ip of your router. It will often work just fine. If not you can probably fine the DNS IPs off your router.
