AOpen’s DSW2012P ~ 20X DVD burner
Discussion in 'Industry News' started by Guest-16, 15 Jun 2007.
  1. Guest-16
    Guest-16 Guest
    The Netherlands, June 14 2007 ~ AOpen introduces a new half-height (5 ¼") optical disc drive, the DSW2012P. This fully-featured DVD/CD burning solution reads and writes DVD±R/RW, DVD±R DL, DVD-RAM and CD-R/RW formats at speeds of up to 20x. All types of optical disc are supported!
    Versatile and powerful, the DSW2012P delivers industry-leading DVD burning performance. It supports 20x burning, 12x DVD RAM, 8x DVD±R DL Double/Dual Layer) and CD-R/RW.Double layer technology dramatically improves the medium’s capacity from 4.7GB to 8.5GB.This unit burns DVD+R/-R at 20x, DVD+RW at 8x, DVD-RW at 6x, CD-R at 48x and CD-RW at 32x and offers a 2MB buffer memory.
    The DSW2012P's excellent stability and high burning speeds of up to 20x make it ideal for home offices and businesses. Special silent-running technology keeps noise in the workplace to a minimum while burning discs.
    Not only does the DSW2012P offer cutting-edge burning speeds, it also incorporates many of AOpen's core technologies. These features include: Auto Balance System (ABS) for decreased disc vibration at high burning speeds, which ensures unparalleled burning quality, Noise Control System (NCS), a unique tray design that minimizes noise levels and Running Optimum Power Control (ROPC) for high precision LASER power control. All these features make AOpen's new DSW2012P a class leader in terms of efficiency, quality and stability.
    Disc formats such as VCD, Photo CD, data, music CD, images, and many more are no problem for this versatile unit. Furthermore, AOpen's DSW2012P is supplied with 2 extra front bezels in beige and black to match any PC housing.
  2. Krikkit
    21 Jan 2003
    Lies! Where's the BDR and HD-DVD support?
  3. Guest-16
    Guest-16 Guest
    I'll email them and ask :D
