AOpen 1000 watts PSU, your extreme power source.
Discussion in 'Industry News' started by Guest-16, 23 Oct 2007.
  1. Guest-16
    Guest-16 Guest
    ‘s-Hertogenbosch, the Netherlands ~ October 23, 2007. A Power Supply Unit (PSU) is a primary PC component related to the stability and performance of the total device. The new AOpen AO1050-12ALN PSU not only provides extreme power output but also gives you ultimate performance with its 1000 watts.
    The AO1050-12ALN supplies up to 1000 watts total output and is equipped with four PCI Express 8-pin/6-pin power connectors, useful for gamers and power users. These PCI-E 8pin/6pin outputs are designed for high-end graphics cards in multi-card deployments such as ATI Crossfire and nVIDIA SLI multi-GPU technology.
    AOpen’s AO1050-12ALN supports all Intel and AMD CPUs, including the Extreme edition CPU. This allows you to install it as an upgrade or in a brand new system. The SATA 4-Pin adapters, nine power outputs for IDE and SATA hard disk drives are ideal for great storage capability. The AO1050-12ALN offers nine modular design cords SATA and six PATA connectors in different colors that can be easily removed or plugged into the PSU. Unplugging the unused cores can improve air flow and clean the inside of the computer housing.
    Besides the power output, the AOpen AO1050-12ALN is also designed for efficiency and cooling. To provide you with silent work surroundings, AO1050-12ALN adapted Silent Technology and Smart Fan Control. These technologies control a 12cm fan speed automatically according to the PSU temperature, and this fan generates less than 22db of noise. Furthermore, it has passed worldwide safety regulations such as UL, VDE, NEMKO, CE, FCC, CB, GOST and BSMI.
    AOpen also provides an 880 watts PSU with the same features. To unleash the utmost performance form your system, the AOpen AO1050-12ALN is your best choice!
  2. Guest-23315
    Guest-23315 Guest
    Looks OK, but if I were spending that much on a 1000W PSU, I'd buy it from a big name manufacturer....
