Hardware Aorus GeForce GTX 1060 9Gbps Review
Discussion in 'Article Discussion' started by Dogbert666, 12 Jun 2017.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Mr_Mistoffelees
    26 Aug 2014
    I can't help thinking the tri-fan cooler is a bit over the top on a GTX 1060.
  3. wardogz
    wardogz What's a Dremel?
    24 Sep 2009
    I have a Zotac 1060 6gb, but the BIG advantage of the RX 580 isn't anything to do with the raw frame rates, it's all to do with Freesync. A freesync monitor is heaps cheaper than a g-sync monitor and that brings heaps of benefits for gaming. Although the card itself performs great, I kind of wish I had bought the RX 580 myself instead of the 1060.
  4. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    Hmmm kinda wish u guys would compare to last gen cards (Geforce 9x0).... This card looks good but not sure if I'm ready to retire my GTX 970 3.5GB......
  5. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    Is it just me or are the Doom charts missing?
  6. IamSoulRider
    IamSoulRider Minimodder
    24 Aug 2016
    They are missing and as advised in the review -
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    1060's are basically 980's but with an extra 2GB of Vram, so it's definitely not worth retiring your 970 for a 1060.
    Personally speaking, the minimum upgrade from a 970 you should consider is a 1070, which is equal to the old 980Ti.
  8. Dogbert666
    17 Jan 2010
    Sorry - should've deleted the Doom page, it's gone now. Hoping to get it working when we get some more interesting GPU hardware back in.
  9. Redbeaver
    15 Feb 2006
    Thank you!
    That will be next year then.
  10. rollo
    rollo Modder
    16 May 2008
    1070 is at worse £70 more expensive for 30% minimum faster card.
    Asus cards are just so expensive for what they offer.
  11. Vault-Tec
    30 Aug 2015
    It's a Gigabyte card.
  12. rollo
    rollo Modder
    16 May 2008
    Asus Strix and Gigabyte Auros are basically super expensive versions of cards that can be had for alot less
  13. Mr_Mistoffelees
    26 Aug 2014
    Vault-Tec, never let the facts get in the way of a good story.
  14. Vault-Tec
    30 Aug 2015
    :hehe:
Tags: Add Tags
