Hardware Aorus X7 Pro V5 Gaming Laptop Review
Discussion in 'Article Discussion' started by Dogbert666, 3 Mar 2016.
  1. Dogbert666
    Dogbert666 *Fewer Lover of bit-tech Administrator
    17 Jan 2010
  2. Hustler
    Hustler Minimodder
    8 Aug 2005
  3. Combatus
    16 Feb 2009
    True, although it weighs nearly 1.5kg more and doesn't have an overclockable CPU. I guess it depends if you're using an external screen too - two 980M SLI is overkill for 1080p.
  4. MightyBenihana
    MightyBenihana Do or do not, there is no try
    8 Sep 2011
    For me the 2 big issues I look for with a laptop is heat and noise (and then size and weight). There is no point having a 980m if it gets as hot as a hairdryer and sounds like one too.
    As someone who has a need for a laptop over a desktop the current trend in power efficiency is more important than overall power and we are seeing the results of such research as mobile CPUs and GPUs close in on their desktop counter parts, but we are still not quite there yet. I am looking forward to seeing what Pascal rings.
  5. Vault-Tec
    30 Aug 2015
    It looks like a cross between an Asus ROG with the MSI shield and the Falcon Northwest logo.
    Kinda sucks that it takes two 970m to beat a 970 though.
  6. SchizoFrog
    SchizoFrog What's a Dremel?
    5 May 2009
    I know you guys like the high-end but can you not review something under £1000?
  7. Hustler
    Hustler Minimodder
    8 Aug 2005
    They can only review what gets sent to them.
  8. SchizoFrog
    5 May 2009
    So you are suggesting that they can't make requests of the manufacturers? Or that the requests would be ignored?
Tags: Add Tags
