Modding Aplus Twin Engine
Discussion in 'Modding' started by olle, 5 Sep 2006.
  1. olle
    olle What's a Dremel?
    26 Nov 2005
  2. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    Why would you want to mod a pre-modded case?
  3. mattthegamer463
    26 Nov 2004
    Its a decent starting place for a paintjob or some snazzy cutting work, plus the front of premodded cases usually look pretty slick so they don't require major bondo to achieve a perticular look. Anyway...
    "OMG! Did someone park a DC9 under your desk?"
    Its probably just about as loud too.
    I wouldn't buy it, but it looks like a decent case to start with.
  4. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    Hmm I think replace the fan with a dremel and put the fan in the dremel chuck the blades anyways. Set it to 35,000 rpm and watch your computer fly around yoru room.
  5. mattthegamer463
    26 Nov 2004
    Get a model airplane single cylinder engine and put it in instead, then it can fly farther than the dremel cord. Weld the side panels on to the top as wings.
  6. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    looks cheap and tacky to me, premod window is awful and it clearly all cheap gray steel inside.
  7. mattthegamer463
    26 Nov 2004
    Yeah true, the steel inside is garbage and wafer thin. Thats probably the kind of case that if you sat on it it would accordian into a pile.
  8. hydro_electric_655
    13 Jul 2006
    That sound slike a fun thing to video
    while the engine is running sit on it.
  9. Skylined
    Skylined Minimodder
    3 May 2003
    How much is that case?
  10. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    I wouldnt say that the metall is thin. I checked on the homepage and the say it has a netto waight of 12kg! Its not really a Lan case IMO!
    Edit: The price is around 80€
  11. olle
    26 Nov 2005
    It costs about 1400sek thats close to 130$us.
    Shouldnt the big fans be quiet, lower rpm´s?! Maybe its just crap but I thought it looked cool..
  12. THEkorean
    THEkorean 42
    10 Jun 2005
    modding potential is only limited by your imagination my friend ;) , that looks like a cool case though, i like the huge fans xD.
  13. olle
    26 Nov 2005
    Thanks! Finally somebody on my side :D
  14. RADCOM
    RADCOM What's a Dremel?
    21 Mar 2005
    I like it in fact I was thinking of buying it. The build quality got a good review and the 250mm are "indeed quiet" If I had water cooling and a decent overclock the large fans would provide a decent flow of air over the hot bits lol.
