Displays Apple 24 inch with PC
Discussion in 'Hardware' started by Asulc, 19 Jan 2009.
  1. Asulc
    Asulc Minimodder
    18 Jul 2007
    Can the Apple 24 inch LED display be used with a pc? I am looking to upgrade my monitor and what high quality. I also love the looks of the monitor.
  2. tominated
    tominated What's a Dremel?
    28 May 2008
    you'll have to wait until mini-displayport becomes more common, then you might be able to find an adaptor
  3. Asulc
    Asulc Minimodder
    18 Jul 2007
    Is there any monitor that is similar in looks and quality that would work with pc?
  4. JaredC01
    JaredC01 Hardware Nut
    24 Nov 2002
  5. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    wtf? they didn't put any inputs on this monitor other than mini displayport? how retarded is that.
    go for a dell fpw240x or the benq fp241. even if you get an adapter for DVI to mini-displayport, you'll probably still want a VGA or HDMI or component input at some point. and the apple monitor might look nice in product shots or in the store, but it has a glossy front which is a real pain to actually use for any work. definitely a case of form over function.
  6. Firehed
    15 Feb 2004
    Apple makes a Mini DisplayPort-to-DVI adapter. $29. Though looking at it again, that might be the reverse of what you need (MDP computer to DVI monitor, not DVI socket to MDP monitor).
    As far as looks goes, it's hard to beat the Apple monitors. I've always liked the Dells and have had good luck with them, but they certainly lack that nice Apple look. If/when I rig up my insane quad-screen madness, I'll probably get three more 24" dells (and before you ask, yes I would use that much screen real estate)
  7. GoodBytes
    20 Jan 2007
    If you want a professional level screen using an 8-bit panel, you can check out this Japanese company called EIZO. Now their market are, and only are professionals, so design of the product is not the main focus, the screen are one of the bests you can find, better or just as good as the high-end of NEC.
    This is what they are coming up with:
    http://www.electronista.com/articles/09/01/15/eizo.s2232w.and.s2242w/
    16.77 million colors and 5 year warranty, so you know it won't let you go for 5 years. :)
    However, for the price of that 1 screen you can get dual monitor from a standard Samsung 6-bit panel monitor. So it's quiet an investment.
    What's the difference between 6 and 8bit colored panel:
    6 bit panels can display 262k colors, the other 16 million colors, is simulated using a process called dithering, hence why they are referred to as being able to show 16.7 million (or 16.2 million) colors.
  8. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    The Dell mentioned above is an 8-bit panel. AFAIK its the same quality, if not better than the Apple monitor that you mentioned.
    Considering that its a lot cheaper and it has many more inputs, it should really be a no-brainer.
  9. Asulc
    Asulc Minimodder
    18 Jul 2007
    What samsung screen would you recommend? I keep hearing good things about them...
  10. Jasio
    Jasio Made in Canada
    27 Jun 2008
    Many companies, including Dell use Samsung/LG Philips/AU Optronics/Chunghwa Picture Tube panels regardless of what sticker/design you pay for. So apart from the fruity looks the Apple is no different than anyone else -- of course, you pay an unnecessary premium with Apple. Heck you can get an IPS panel for $800~ which is superior in every way to TN+Film.
