News Apple patches MacBook Pro throttle bug
Discussion in 'Article Discussion' started by bit-tech, 25 Jul 2018.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. jb0
    jb0 Minimodder
    8 Apr 2012
    Another day, another embarrassing QA failure from the fruit. Seriously, do they even HAVE a QA team anymore?
  3. RedFlames
    23 Apr 2009
    At least they actually acknowledged there was a problem for once... and then actually 'fixed' it...
    Usually you get some 'you're probably just holding it wrong' style fob-off and then the problem gets ignored.
  4. MightyBenihana
    MightyBenihana Colour my life with the chaos of trouble
    8 Sep 2011
    I'll wait to see some reviews on how the chassis copes with the heat first.
  5. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Apparently they are coping fine now. The fan curve has been made much more aggressive and the CPU voltages lowered.
    So now it performs in line with the rest of the MBP line, which is to say it's faster than the i7 model but slower than an i7 or i9 windows machine that has better cooling and higher sustainable clock speeds as a result.
Tags: Add Tags
