News Apple sued over MagSafe risks
Discussion in 'Article Discussion' started by CardJoe, 7 May 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Never had a problem with mine, it's one of the best design features on the laptop tbh.
  3. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I don't understand what people do to their magsafes to get the above mentioned issues.
    My magsafe adapter (admittedly out of regular use, now, owing to the lack of Mac) has been being used, wound up, chucked in bags etc, for ~2 years. It's not been treated like it's made of glass and spit, either. It's still in perfect working order, with only some marks on the cable, which I bet'd come off with a bit of half-arsed effort..
    I think this is PEBKAC rather than bad design. Especially since it's not occurring with every single brick, which you'd expect for something that's supposed to be a massive manufacturing defect..
  4. Johnny Bravo
    Johnny Bravo What's a Dremel?
    1 May 2006
    Actually this did happen to my flat mates PSU. No fire but it did get hot enough to burn the white plastic and cause alot of alarm. To be fair it's not strictly a major design flaw; wear and tear and hardly be levied at a company but it does indeed happen.
  5. p3n
    p3n What's a Dremel?
    31 Jan 2002
    When they replace damaged PSU's without question its kinda silly to sue....
  6. Goty
    Goty Minimodder
    13 Dec 2005
    This is just a result of the litigious society here in the US, and especially the vocal minority of complete idiots in California. I highly doubt the failure rates of the power bricks are anything to be alarmed about.
  7. TGImages
    TGImages Grandpa
    11 Aug 2004
    Mostly user abuse IMO.
    I support dozens of laptops for users who regularly travel. A variety of brands although most at Dell. Same machine, same adapter. One user needs a new power adapter every year or so due to plastic separation and fraying. Another user will go 4 years and the equipment still looks like new. Same with cell phones, same with... etc.
    Not to say that some stuff does have design flaws but in general treating the equpiment properly usually prevents almost all of these issues.
  8. DarkLord7854
    DarkLord7854 What's a Dremel?
    22 Jun 2005
    "When you twist the cable 120 degrees multiple times, the cable can fray and damage! It's a manufacturer defect!" :rolleyes:
    I don't own a mac, but I have a few friends that do, and I always see them bending the connector in all sorts of weird and sharp angles. I guess people assume that cables that plug in straight are actually not intended to be left in that position.. :lol:
  9. wafflesomd
    wafflesomd What's a Dremel?
    22 Oct 2005
    I've repaired one before. It's pretty obvious why it happens.
    Most power supplies have a thicker, structured piece of rubber the helps strengthen the joint. The MagSafe's really don't.
    Plus, two conductors go from the PSU to the laptop. Though rather than remaining as two individual cables, the ground meshes out and becomes a shield. That, combined with the very thing outer layer of the cable, makes it pretty prone to tearing.
    This isn't user abuse, it's just a piece of crap.
  10. Zurechial
    Zurechial Elitist
    21 Mar 2007
    Suing Apple over design flaws seems like a pretty smart way to recoup the losses of paying for overpriced technology.
    Whoever said Mac users were foolish? :D
    I have to say I like the concept of the socket, though.
    With some modification to alleviate this problem it's a design I'd be happy to see gaining popularity beyond the mac.
    It'd be especially useful for external hard drives and enclosures - How many drives have been killed by people tripping over the wire?
  11. Psytek
    Psytek What's a Dremel?
    23 Dec 2008
    I don't understand which part of the cable is meant to be dangerous. I don't know anyone whose magsafe emits 'sparks'.
  12. Johnny Bravo
    1 May 2006
    the shielding inside also acts as ground. However cus the power cable is so thin it can bend quite tightly and after some time the shielding frays and eventually strips the insulation on the live central wire. when that happens its shorts overheats and burns.
  13. Digitalize-
    Digitalize- What's a Dremel?
    23 Apr 2009
    Just wish they would apply the MBA Magsafe to all the Laptop line, right angled connector please!
  14. DarkLord7854
    22 Jun 2005
    Correct me if I'm wrong but I believe it's patented by Apple and I highly doubt you'll be seeing magnetic connectors outside of Apple products for many many years..
  15. ZERO <ibis>
    ZERO <ibis> Minimodder
    22 Feb 2005
    You could always DIY and not half to wait! Also if you made your own you could use a better cable that does not break.
  16. OleJ
    OleJ Me!
    1 Jul 2007
    I concur.
    It happened to a family members MBP and was not caused by abuse.
    For some reason Apple disregarded proper sleeving and strengthening of the connecting ends of the power adaptor cable.
    There has been countless incidents where either the end near the power brick or the one at the mac end starts melting and short circuits.
    It's "just " an engineering flaw and I think it's a shame Apple hasn't adressed it. This will hopefully force them to improve their design.
Tags: Add Tags
