Networks apple wireless network
Discussion in 'Hardware' started by seebul, 8 Oct 2005.
  1. seebul
    seebul Minimodder
    9 Aug 2005
    ok, i have just bought an airport extreme to use with my dads powerbook, i use AOL broadband which uses a USB adsl modem, which i thought would be fine since the airport exteme has a USB connection on the back of it. But when i got the airport i found i couldn't use the USB on the airport to share my conection :wallbash: Plus the modem tht aol supplied me with doesn't have an eternet port on the back so i am a bit stuck really! any1 got any suggestions of what i should do??
  2. MrWillyWonka
    MrWillyWonka Chocolate computers galore!
    25 Jul 2004
    Well, it seems to me from some google image search that there is a phone line to the APE, so plug in the phone line into it and configure the settings. The APE I assume would also be compatible with windows computers, like normal routers being compatible with all OS's.
  3. seebul
    seebul Minimodder
    9 Aug 2005
    excuse me for being stupid but u've lost me.
  4. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    From what he has seen looking at Google Image pictures of the Airport Extreme it looks like it has a built in modem so try plugging your phone cable that's plug into your modem you got from AOL into the Airport Extreme and see if you can configure it up.
  5. MrWillyWonka
    25 Jul 2004
    Precisely!
  6. seebul
    seebul Minimodder
    9 Aug 2005
    yeh but the in built modem is only a 56 k one for dial up.
  7. MrWillyWonka
    25 Jul 2004
    You sure? I haven't that I don't think. Whats the model number of the APE (AirPort Extreme)?
    Don't forget the word "modem" does not mean 56k, a telephone line will plug into a 56k modem AND a broaband modem!
  8. CaseyBlackburn
    27 Jul 2004
  9. MrWillyWonka
    25 Jul 2004
    Tbh, I think that is a bit odd!
    Best thing to do is to get a normal router (not apple branded), they will work for any computer. I reccomend Belkin and not Linksys or D-link. Netgear are good too, and quite cheap now.
  10. CaseyBlackburn
    27 Jul 2004
    Apple Branded hardware works for any computer because its just the 802.11x standard. All he has to really do is buy a new modem with an Ethernet out so it can be plugged into the Airport Extreme.
  11. MrWillyWonka
    25 Jul 2004
    Yea i know, but I said "not apple branded" cost they seem to rip people off! :hehe:
  12. CaseyBlackburn
    27 Jul 2004
    Well he has already bought it so buying another router would be just a waste when all he needs is a new modem with Ethernet out.
    OT: Apple really rip people off with the Ipod. I love my Creative Zen 20GB.
  13. seebul
    seebul Minimodder
    9 Aug 2005
    thanks guys, i'll be buying a new modem 2moro then.
  14. MrWillyWonka
    25 Jul 2004
    Read it and make sure it says ADSL gateway or Broadband Modem, or something that indicates you can share a broadband Internet connection.
  15. seebul
    seebul Minimodder
    9 Aug 2005
    cheers.
  16. CaseyBlackburn
    27 Jul 2004
    I take it that that means everything is working.
  17. seebul
    seebul Minimodder
    9 Aug 2005
    yep it is now!
