Apple Apple wireless networking sucks ass
Discussion in 'Software' started by Guest-16, 26 Aug 2006.
  1. Guest-16
    Guest-16 Guest
    For starters airport has no WPA, only WEP. And it doesn't work with our netgear router, it will ONLY connect to non-encrypted networks. I can't even get it to connect to our router through the wired connection!? Ive no idea how. It even has DHCP so it should be a simple pnp effort but it isnt. Apple is great for stuff it produces itself, but add some other manufacturer into the mix and everything goes to ****. At least windows works. :miffed: It's not for me, it's for my brother and his MacBook.
    Would someone please explain to me how to get wireless working with a netgear router, as I am NOT unencrypting our network. It wont work with 40 or 128bit WEP and I know the key is correct. The router is set to g only and is on channel 3.
  2. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    Really? My wife has a Mac mini (PowerPC version) which connects to the wireless network (Belkin bridge) using WPA just fine. Don't remember any problems setting it up...
  3. mookboy
    mookboy BRAAAAAAP
    15 Feb 2002
    I could be reading that wrong, but am I right in thinking you can't get the only Mac you have to connect to a previously PC only wireless network as the router won't allow you to connect with the WEP password set?
    Have you tried adding a $ (dollar sign) infront of the WEP password on the Mac first? I know that on both my old D-Link and current Belkin jobbies I need to type in the WEP password prefixed by a $ or it won't recognise it.
  4. Guest-16
    Guest-16 Guest
    You, Sir, are a Genius of Genius Bar proportions.
    Still cant get ethernet to work. Have DHCP enabled and it sees the network but the "apply" button doesnt highlight!?
  5. Gordy
    Gordy Evil Teddy
    17 Apr 2001
    You should just use a normal wireless router belkin or netgear the apple one is crap. I run my laptop via my netgear wireless route using wpa fine :)
    DHCP should just work, sounds like their is something odd going on, may I suggest popping over to http://forums.macrumors.com/ and seeing if anyone their can help? :)
  6. simon_C
    simon_C Minimodder
    13 Nov 2005
    no i have this dhcp issue sometimes myself. turn off the mac, then restart your router and modem simultaneously. wait for them router and modem to finish booting, then turn on the mac. it should see that its on a network.
    dont need to hit apply, dhcp does things automatically. only need to use the apply button when a gateway or dns server is added. or if you change the protocol.
    And dont you just love it how people just automatically say something sucks ass because they cant figure out how to use it correctly?
  7. Sam0r
    Sam0r It's been a while
    24 Jun 2005
    You don't need to click apply.
    Wireless on Mac's is pretty lame if you use encryption in all honesty, but if you don't its perfectly fine.
    On the DHCP front, you don't need to click apply unless you're changing from Static to Dynamic (DHCP) or vice versa.
    With DHCP you need to click 'Renew address' or something like that.
    Try setting the ethernet port speed manually, set it to this, just to make sure it can get a connection:
  8. cderalow
    cderalow bondage master!
    23 Jan 2002
    funny how i've never had an issue with that...
    older version of OS X?
    OS 9 maybe?
    I know 10.2 or better I've never had to prefix with $ using any router or connecting any system to my airport extreme or airport express base stations
  9. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I had to use the $. I think it depends on whether you're using a hex key or a ascii one. I remember having a lot of fun and games with it, there's no doubt it's not the easiest thing in the world. Having said that, nor is wireless in Windows so I'd say it's about evens.
  10. EK-MDi
    EK-MDi What's a Dremel?
    12 Mar 2006
    Wow! That is really bad, LOL. That's Macs for you, :hehe:.
  11. simon_C
    simon_C Minimodder
    13 Nov 2005
    EXCUSE me? did you even read any of the posts in this thread?
  12. Sam0r
    24 Jun 2005
    Get out.
  13. cderalow
    23 Jan 2002
    seriously though, did you read?
    it was a simple case of not knowing an odd thing about a mac/mac os...
  14. Abydox
    Abydox What's a Dremel?
    6 Nov 2005
    dunno what you do wrong but i've setup a couple of networks with a mac included and it works fine. I used the $ only on 1 of the networks whch was using a bekin router.... i use a cisco linksys myself and that works perfect 2
