Case Mod - In Progress AppleCoreDuo
Discussion in 'Project Logs' started by Cyprio, 2 Dec 2006.
  1. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Sweet. Looking tight.
  2. GuardianStorm
    GuardianStorm Active Member
    26 Apr 2005
    Excellent and professional looking as ever :)
  3. SirShaw
    SirShaw New Member
    24 Aug 2003
    looking sweet man but at least to me the backlighting looks a bit dull, is it just the camera and its brighter in person or is it really that dark? Cant wait to see the UV highlights :)
    top notch mod though bud! :)
  4. kickarse
    kickarse New Member
    6 Oct 2004
    Simply can't wait to see the finished project!
  5. Cyprio
    Cyprio G5 Supermodder
    2 May 2006
    Well, i will have more LEDs in the bottom and possibly sides but i am going for a minimal white ambient light and an intense UV on the blocks to create a contrast.
    That's the plan at least. :D
    Cyp.
  6. Evenge
    Evenge Member
    16 Sep 2006
    Cool! I don't know why but those couple last pics reminded me of something like midnight city lights. Some dark and lonely London alleys maybe? ;)
  7. Pete Wright
    Pete Wright New Member
    16 Aug 2004
    Cyprio,
    Been following this for a life time it feels but it's been well worth it. You've an amazing case but also a very nice pad by the looks of things. I've finaly got my self a case. APPLE INTEL MAC PRO, dual optical drives etc etc.
    One question, does your optical drive fit through the opening as the photos i seen on G5 etc all are thin
  8. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    sorry if I step in here............
    but he mentioned it 3 pages back in
    post#272
    and
    post#273
    please :read:
    Alan
  9. Breach
    Breach Modding in Exile
    20 Jun 2005
    This looks awesome! I really love the way that the core mods look totally stock, and then you actually modded from there. Well done! Cant wait for the completion.
  10. Cyprio
    2 May 2006
    Pete, if you give me an hour i will update with the DVD drive bezel finished. :) Normal drives work fine but its a bit of a fiddle to get the bezel to open correctly as the drive has to sit at exactly the right position. I am happy with 4 out of 5 attempts opening with no glitch right now. :)
    Of course my case is the older version so i dont know the exact size of yours - i would imagine they are the same.
    Breah and The Alien = :thumb:
    Catch you a bit later.
    Cyp.
    ps the flat is amazing but alas its a rental and they are selling it so will be moving on soon. :(
  11. Cyprio
    2 May 2006
    This will look like a rather short update although it took me the best part of 7 hours to complete! I basically wanted to finish off the top of the case so that i wouldn't have to touch it again (hopefully!). This involved, moving some of the LEDs that werent quite in position, attaching the DVD bezel so that it opens freely without sticking (harder than i thought) and mounting the DVD drive at exactly the right height so that it opens the bezel rather then just smashing into it and staying closed!
    But before i would do all that i needed to do some more 'hole cleaning'... this is getting rid of the polishing gunk that was left over from the paint job. It has dried as a white powder inside the holes and is quite noticable.
    Top are cleaned, bottom are not.
    I have tried using pipe cleaners to get rid of it but this didnt work that well so i have moved to using rolled up screen wipes.
    The alcohol seems to get rid of the powder immediately.
    There are 30 holes in each row... i havent counted how many rows there are!
    Next i moved onto the front bezel sorted. It is bolted on from the sides and also the front using spacers. The front of the case bows in at the middle so it was hard to find a spot where it didnt rub the aluminium.
    Spacer - made from a BIC pen ink tube!
    Bezel in place:
    In order to fit the DVD drive i cut 2 strips of perspex and bolted them to the bottom of the drive using button head bolts. This raised it to the right height for the bezel.
    I then drillled 6mm holes in the metal plate so the bolts slotted into these snugly:
    DVD drive in place:
    Open drive bay:
    Here are a few videos i took today as well (sorry 2 of them are so dark - they were taken at end of day):
    DVD drive test:
    Door mechanism in place and working fine:
    Top of case done, door mechanism in place:
  12. Pete Wright
    16 Aug 2004
    IPA in spray can dude, just go over the lot that will get rid of it all im more than sure of it. I use it to clean my mobos after benching with Ln2 for 10 hours+. Im really pleased with how your porject has come out. It's inspiered me and show me what direction to go. By the way size torx fitting are the bolts that hole the inner to the puter that go around on the inside edge?
    Can't wait to get mine
  13. Cyprio
    2 May 2006
    IPA? Would that damage my paint at all?
    The torx are size 8 on my case - if you mean the ones that hold the inner cage to the outer one.
  14. Cyprio
    2 May 2006
    Pete - you got me thinking about the 'thin apple drives'. I took the front bezel off the DVD drive itself and it seems like this helps open the bezel - no jamming yet! :)
  15. headala
    headala New Member
    9 Oct 2005
    How can Indian Pale Ale clean his computer?:eyebrow: Please explain :D
  16. sik19
    sik19 New Member
    2 Jan 2006
    Whoa i relly like the drive cover. It looks so cool when it slides down. Great Work!
  17. DoOb's
    DoOb's Overclocker/Modder
    7 May 2007
    Brillant Work Cyprio, This is the best case out , You doing this case very very well, Everything just looks perfect man. Keep it up.
  18. eNoremac
    eNoremac New Member
    23 Oct 2007
    About the DVD drive for Mac Cases..
    AS to prevent jamming.. I took my front plate off the DVD since as we both see the Apple G5 doesn't have any. I did a test on that and that worked just fine without slamming through it.
    A question for you Cyprio about the DVD drive.. Did it require any special wiring or you just basically solder the wires to where the switch used to be and moved the switch to the end of the wires correct? :confused:
    Other than that keep it up.. It's coming together very very very nicely! :clap:
  19. Cyprio
    2 May 2006
    Thanks. :)
    Taken from post 70 in the log:
    Hope that helps.
    Cyp.
  20. crimandevil
    crimandevil New Member
    30 Jun 2004
    I just use this and set it as a keyboard shortcut.
