News Apple's new iMac Pro launches tomorrow
Discussion in 'Article Discussion' started by bit-tech, 13 Dec 2017.
  1. bit-tech
    bit-tech Supreme Overlord Lover of bit-tech Administrator
    12 Mar 2001
    Read more
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Isn't 16GB of HBM2 twice that of any commercial available Vega, or am i mixing up my RX's and PRO's.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    They claim 500W total heat dissipation - They should name it iTrottle.
    Guest-23315 likes this.
  4. Anfield
    Anfield Multimodder
    15 Jan 2010
    The Vega Frontier Edition has 16GB HBM2, as does the Radeon Pro WX9100.
    Agreed, cooling that hardware in that form factor just isn't possible without some massive compromises.
    Dell and Phillips both have 5K monitors available.
  5. RedFlames
    23 Apr 2009
    Like the mac pro, i'm not convinced the iMac Pro won't cook itself... maybe not immediately but certainly after a few months of dust buildup.
    Dell made a 5k @ 27" display, as did HP, LG and a few others... but given as far as i can see none are availaible to buy anywhere, they only made 1 of each...
    Apple likely have what little supply of such panels there is to themselves.
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    My bad, I forgot the LG one.
    A handful each sounds about right for Dell and Phillips, I don't think ones from HP and others ever even made it past an empty announcement.
    Not like any of it matters, scaling issues of windows with hyper niche resolutions beyond 4K would not be a fun experience, so you'd only ever do it on a Mac anyway for a couple more years.
  7. RedFlames
    23 Apr 2009
    Isn't that the one that had to be pulled from sale for a bit because it didn't work? [IIRC it threw a hissy fit if placed too near a wifi router/access point]
  8. RedFlames
    23 Apr 2009
    The PC route does give you more flexibility re: hardware... and the knowledge that it won't cook itself under load [if the person building it has half a clue].
    The only thing you'd have to sacrifice on PC is Thunderbolt [...probably] and the end result won;t be quite as compact.
  9. Pliqu3011
    Pliqu3011 all flowers in time bend towards the sun
    8 Aug 2009
    What's a "double-wide graphics card"?
  10. Anfield
    Anfield Multimodder
    15 Jan 2010
  11. Pliqu3011
    8 Aug 2009
    That kind of makes sense. Thanks. :thumb:
Tags: Add Tags
