Storage Application/data drive recommendations.
Discussion in 'Hardware' started by Yadda, 16 Aug 2016.
  1. Yadda
    Yadda Minimodder
    25 Jul 2003
    I need a new secondary drive and seeing as it's been a while since I bought a hard disk, I thought I'd ask for recommendations.
    I'm after either a standard drive or a hybrid depending on cost, at least 1TB.
    Any good deals about? Cheers.
  2. Mighty_Miro_WD
    Mighty_Miro_WD What's a Dremel?
    15 Apr 2016
    Hi there.
    The best choice depends more or less on what kind of applications are you planning to install on the drive.
    For instance, if you're after some light gaming and programming you can take a look at WD Blue which is meant for everyday computing and a lot of people are combining it with a SSD for their OS.
    http://products.wdc.com/support/kb.ashx?id=CVzjBj
    Another option would be WD Black if you're more after performance since it has a firmware that will give you faster loading times (like a dual-core CPU for instance). It is designed for heavy gaming, big workloads and intensive file usage.
    http://products.wdc.com/support/kb.ashx?id=jmK4D4
    Hope this helps and feel free to ask any questions you may have. :)
  3. Yadda
    Yadda Minimodder
    25 Jul 2003
  4. David
    7 Apr 2009
  5. Yadda
    Yadda Minimodder
    25 Jul 2003
    That's good to hear, cheers. They don't hang-around at Aria, my order my despatched 21 minutes after I placed it. :hip:
  6. Yadda
    Yadda Minimodder
    25 Jul 2003
    ...and it got here this afternoon, about 23 hours after I placed the order. That's pretty mental. :lol:
