Linux apt source
Discussion in 'Software' started by Woodstock, 26 Nov 2007.
  1. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    ive been trying to install debian, from the netinstaller. all goes fine dhcp works, partitions fine, installs fine then it asks if i want to configure the package manger, which of cause i do, so i select New Zealand FTP, and get this error on a red screen [!!] Configure the package manager Bad archive mirror, the specified Debian archive mirror is either not availble, or does not have a vaild release file on it. please try a different mirror. then gives options continure or go back, if i click continue i can choice another mirror the same way but regardless of which i choice i get the same mirror if i click Go Back it allows me to manually enter the address but yet again the same mirror any suggestions on what to do
  2. Glider
    Glider /dev/null
    2 Aug 2005
    Try pressing ALT+Right (or ALT+F2) and enter (via vi or nano) in /etc/apt/sources.list
    Code:
    deb ftp://ftp.belnet.be/debian/ unstable main non-free contrib
    deb-src ftp://ftp.belnet.be/debian/ unstable main non-free contrib
    deb ftp://ftp.belnet.be/debian/ stable main non-free contrib
    deb-src ftp://ftp.belnet.be/debian/ stable main non-free contrib
    deb http://security.debian.org/ stable/updates main
    and just skip the "setting up apt" step
  3. Woodstock
    10 Sep 2006
    well this machine is pissing me off no end, i tried what you said but i had to make the apt directory myself and i am pretty sure there is other files in there, so i thought what the hell ill give it a go anyway to recieve on the attempted reboot grub loading ,please wait Error 15, anyway im off to have a bit of a chill before i kill this machine
