Case Mod - In Progress Aqua-Pcs - Project BloodRage - 25th Feb - Panel Planning..
Discussion in 'Project Logs' started by aquatuning, 19 Feb 2009.
  1. aquatuning
    aquatuning What's a Dremel?
    5 Jul 2006
    Welcome to Project BloodRage - By Aqua-Pcs: Liquid Designs Team​
    Project BloodRage is the latest project to be under taken by Aqua-Pcs in-house Watercooled case department, Liquid Designs.
    As you can probably guess the project is based around Foxconns BloodRage motherboard. Using this as the base we will be creating a themed case for use at Multiplays I36 Lan Party in April.
    The projects aim is to create a simple, functional mod focusing on sheer cooling power.
    We will use this log as the man point of call where you can track the progress of the build and give comments / ask questions and for those of you going to i36 you can come and see it in the flesh!
    As we begin we would like to take this opportunity to thank the projects sponsors who will be providing vital part to this project.
    [​IMG][​IMG][​IMG] [​IMG]
    If you would like to become a sponsor please e-mail sales "AT" Aqua-Pcs.co.uk for details.​
    Current System Specs:
    Case: MM Cube
    Processor: Intel Core i7 965 - Provided by Intel
    Motherboard: Foxconn BloodRage - Provided By Foxconn
    Memory: OCZ DDR3 PC3-16000 Blade Series Low Voltage Triple Channel - Provided By OCZ
    Graphics Cards: TBA
    Hard Drive: OCZ Vertex Series SATA II 2.5" SSD - Provided By OCZ
    Optical Drives: TBA
    Power Supply: OCZ 700W ModXStream Pro Power Supply - Provided By OCZ
    Keyboard: OCZ Alchemy Series Illuminati Keyboard - Provided By OCZ
    Mouse: OCZ Equalizer Laser Gaming Mouse - Provided By OCZ
    Cooling Loops: TBA
    Current State of the case:
  2. aquatuning
    5 Jul 2006
    The shell of the case that you can see in the first post will be a nice gloss black.
    These parts below im thinking of doing a bright gloss red to compliment the board:
    Current Idea for the drive bays is:
    1 x Blue Ray Drive - Top
    1 x XSPC 750 Bay Pump - Loop one Black Coolant
    1 x XSPC 750 Bay Pump - Loop Two Red Coolant
    Comments Welcomed
  3. Theovaz
    Theovaz What's a Dremel?
    17 Dec 2008
    Looks promising:thumb:
  4. aquatuning
    5 Jul 2006
    OCZ have now joined the sponsors list :)
    Check out the specs in post 1
  5. Degenerate83
    Degenerate83 What's a Dremel?
    4 Nov 2008
    nice to see ya here nitrix! will follow this one with some interest!
  6. aquatuning
    5 Jul 2006
    Thanks mate,
    Just working on panel designs now and will have an update shortly.
  7. aquatuning
    5 Jul 2006
    Just a quick update - took a delivery today that would put a smile on anyones face:
    Again Thanks to Intel for sponsoring the project :)
  8. aquatuning
    5 Jul 2006
    Ok so today im looking at the panels of the case as you can probably see from the pic below these have already been laser cut fr a previous mod so im going to have to get rid of the middle part.
    The red line shows the "rough" cut that will be made. I have two identical panels that i will be doing the same cut on and these will form the side panels of the case.
    For the roof i have a solid panel that will hopefully get CNC'd with quite a cool design ;)
    We also got some more goodies today from OCZ - Thanks guys, check out what we got in the first shipment:
    The interesting thing to note about this little lot is actually the CPU block, we have been stocking the Hydroflow for a while now but this ones different:
    They now have i7 brackets as standard! it will be interesting to see what sort of temps we get out of it as the XSPC delta which uses a similar design is doing very well on i7 CPU's
  9. PrometheusCon
    PrometheusCon What's a Dremel?
    11 Oct 2004
    Nice shipment fro OCZ! Also that's a pretty pimpin' processor you have there.
  10. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    WOW this is going to be a beast!
  11. aquatuning
    5 Jul 2006
    Cheers guys,
    The panels have now gone to the CNC place to be cut and i have just picked up the BloodRage directly from Foxconn :)
