Aquacool Monsta- fitting question
Discussion in 'Watercooling' started by hairyknacker, 20 Nov 2014.
  1. hairyknacker
    hairyknacker Member
    25 Jan 2012
    Guys and Gals- due to layout of new build- and a lack of tubing- can I use the single end fitting as an outlet or will it effect performance? Rad comes with no manuals
    If I can use it, I would save a lot of tubing and would make the routing simpler and more hidden
    thanks
  2. jinq-sea
    15 Oct 2012
    I wouldn't, as I would expect it means only one 'half' of the rad will be being used!
  3. hairyknacker
    hairyknacker Member
    25 Jan 2012
    ta- managed to get it sorted without having to use it and still look ok:thumb:
  4. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Good choice on the Monsta :D I have one myself. Works very well with slow fans in push/pull I've found.
