Graphics Arctic Accelero Twin Turbo II
Discussion in 'Hardware' started by Kronos, 26 Dec 2012.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
  2. Guest-56605
    Guest-56605 Guest
    In a word yes
    I'd safely say you'll shed 15°C on load temps most likely closer to 20°C
  3. Blogins
    Blogins Panda have Guns
    3 Aug 2010
    No! The DirectCU II is pretty much the perfect cooler.
    To put things in perspective I have GTX 670 SLI and my ASUS DirectCU II occupies the top slot where typically it would be 10 degrees+ the temperature of the bottom card. By putting the ASUS DirectCU II fans on 100% temperatures in game across both cards is equal! Also the sound from the DirectCU II isn't that loud at 100%.
    I would recommend sticking with the stock DirectCU II.
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    Conflicting views guys. The games I am playing at the moment are not really pushing the card.(Portal 2 User content, Rage,Far Cry 3) so I have not really noticed any particular fan noise.
    I have just got the whole rig down to an acceptable noise level by trying different case fans. My signature case comes with 2 x 120mm and 1 X 140mm and was noisy. Bought these and am very happy. http://forums.bit-tech.net/showpost.php?p=3241478&postcount=2
    Will see if there are any other views. Cheers.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Ive got the DCUII on my 6970 and have to agree its noisy. i have manually fitted it to a fan controller as even with a fan profile setup anything more than 20% fan it goes mad.
    Ive been hunting for a usable aftermarket cooler but keep hitting problems as ASUS decided not to use the reference card design!
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Does that apply to the Direct CU 11 GTX 670?
  7. legoman
    28 Feb 2010
  8. Kronos
    Kronos Multimodder
    6 Nov 2009
  9. hamza_tm
    hamza_tm Modder
    10 Apr 2012
    Far Cry 3 would definitely push a GTX 670 I should think!
    It heats my GTX580 right up with just high details, at about 40-60 fps
