Arctic Silver
Discussion in 'Hardware' started by arrowswake, 19 Aug 2004.
  1. arrowswake
    arrowswake What's a Dremel?
    3 May 2004
    I might just be imagining this, but I seem to remember something about Arctic Silver 5 needing some time before it works right...
    This is for the compound, not the adhesive... I could be dreaming or something, I have no idea...
    If it DOES need time, will it WORK before that time is up, just not at full effiency? Or should I wait however long it is...? Thanks.
  2. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    once artic silver has heated up and cooled down for some time (weeks) some people find that their temps drop a little as it has finally bonded properly (not bonded as in permanent)...
  3. arrowswake
    3 May 2004
    Okay, so there would be no problem in applying it, and using it as soon as I put my case back together?
  4. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    No problem at all. Apply the AS5 and just watch your temps fall, then after a couple of weeks just watch them fall some more.
