Modding Are LianLi Bezels standard size
Discussion in 'Modding' started by Risky, 29 Aug 2003.
  1. Risky
    Risky Modder
    10 Sep 2001
    I don't have a Lian Li but a GW802 with the Bezel removed. I may want a replacement bay blaking plate and wondered if these would do.
    Thus the question in the title. Thanks in advance.
  2. Pflumingo
    Pflumingo givem the bird.
    17 Jul 2002
    yes... You meen the drive bezels or the whole front assembly... Each of the drive bezels are standard size... otherwise you couldn't put a cd in them...
  3. tk421
    tk421 Idiot.
    15 Jan 2002
    im pretty sure the lian li drive blanks are proprietary .. i havent seen anything like em on another case .. but then again i havent had a globalwin ... the lian li's lock in place much differently than most cases ..
    http://pcmods.com/_images/products/PC-5X(320).jpg
    look at that pic .. the 2 little bumps on each tab lock into the drive cage ... not like the side-tabs dealies that most cases use ...
  4. Risky
    Risky Modder
    10 Sep 2001
    Not so good then. I just wanted some generic- type blanks that I could screw in.
