Motherboards Are there any mATX AM3+ boards worth buying?
Discussion in 'Hardware' started by Parge, 27 Nov 2013.
  1. Parge
    16 Jul 2010
    My friend has a mATX case and with BF4 and and CryEngine games liking the cores I'm thinking about recommending a 8320. Trouble is, I can't find a single good AM3+ mATX board.
    Anyone know of any?
  2. Harlequin
    Harlequin Modder
    4 Jun 2004
    get an FM2+ board - AM3+ is a dead socket
  3. Lance
    Lance Ender of discussions.
    6 May 2010
    I have a bulldozer chip that I have on an ATX that I would like to move to a mATX, so I would also be interested in the answer.
  4. sandys
    sandys Multimodder
    26 Mar 2006
    Surely anything will do as a mATX is not going to need SLI or power user features and the like so just get the right no of memory slots and the appropriate GPU slot, job done, probably cost you < £40.
    Just check manuals for tweaking options.
  5. Boorach
    Boorach Minimodder
    16 Feb 2013
    Simple answer - no! You won't get anything better than 4+1 power phases so overclocking is out of the equation. You wont get sata3 or many usb3 ports either. As far as I know Harlequin is right in saying AM3+ is a dead socket as they dont plan on developing it any further. For mATX your choices are either intel or FM.
  6. Parge
    16 Jul 2010
  7. Boorach
    Boorach Minimodder
    16 Feb 2013
    I have one of these sitting in my bedroom after giving up on the idea.
  8. Parge
    16 Jul 2010
    How far did you get with OCing? Quite a lot of people seem to say a light OC is within its capabilities, so maybe bumping an 8320 (3.5Ghz stock) to 4Ghz (same speed as an 8350) might be fine?
  9. mrbungle
    20 Sep 2004
    Absolute crap, had one and a stock FX6300 throttled after a minute of full load.
  10. Parge
    16 Jul 2010
    Ah, so it sounds there just isn't any good AM3+ boards out there then.
  11. Boorach
    Boorach Minimodder
    16 Feb 2013
    I gave up on it as couldn't get the system to run stably even at stock speeds.
  12. AlienwareAndy
    AlienwareAndy What's a Dremel?
    7 Dec 2009
    If you can find one with 4+2 power stages (as opposed to 4+1) then you should be OK. My SLI rig is running a £59 board with 4+2 (ATX mind) and I can get 4.3ghz out of it without it throttling. Which is more than enough power really.
    TBH and I really hate to say this but Asus have pretty much got AM3+ sewn up. Gigabyte make some nice boards but many are plagued with iffy bioses that cause problems when overclocking.
    https://www.asus.com/Motherboards/M5A78LMUSB3/#support
    http://www.amazon.co.uk/Asus-M5A78L...qid=1385556085&sr=8-1&keywords=am3++micro+atx
    Is about your best bet. You will need to get a cooler on those VRMs though. I assume they are 4+2 but even with 4+1 I got 4.2ghz. But yes, cool off the VRMs and that board should do a fine job.
    Ed. OK it seems that board is 4+1 with no VRM cooling. You're going to have to put some cooling on there tbh.
  13. sandys
    sandys Multimodder
    26 Mar 2006
    What about the Asus M5A78? I have been running its predecessor (m4a78) for a few years in an overclocked undervolted HTPC, no issues.
    Sounds like AMD need to put their desktop chips on the more modern APU platforms.
  14. teppic
    teppic What's a Dremel?
    18 Jul 2011
    4+2 won't make much difference over 4+1, it depends on the quality of the design not just the number of mosfets. A good Asus 4+2 VRM is likely to match or beat a poor 8+2 from MSI.
    The problem with 700/800 series boards is that they were never designed to take 6-8 core PD CPUs. It's the disadvantage of forward compatibility with AM3+.
    Basically, no - there aren't any MATX boards that can run an 8320 properly. The 6300, just about.
  15. AlienwareAndy
    7 Dec 2009
  16. mrbungle
    20 Sep 2004
    The M5A78 is turd for FX chips, end of lol
  17. teppic
    18 Jul 2011
    Is the case expensive? There are decent ATX cases for £30-£50, some barely bigger than typical MATX cases. There are loads of good ATX options for AM3+ (all Asus, though).
  18. AlienwareAndy
    7 Dec 2009
    It probably is but I've had two weak boards now and both overclocked fine. The only deficit I can see is the fact that the M5A78 doesn't have any VRM cooling at all, and it will 100% be the VRMs overheating and throttling, not the chip.
    It might be worth a twenty minute mod....
  19. Instagib
    Instagib Minimodder
    12 Mar 2010
    The 7xx chipsets, that the mATX boards tend to favour, were released back in 2008. Even then, they were't really aimed at the enthusiast segment of the market.
    (Read; they sucked then, and they still suck today.)
  20. RedFlames
    23 Apr 2009
    No.
