Modding are these any good?
Discussion in 'Modding' started by delphia, 28 Oct 2002.
  1. delphia
    delphia What's a Dremel?
    9 Sep 2002
  2. m00min
    m00min What's a Dremel?
    6 Jul 2002
    maybe.
  3. japala
    japala What's a Dremel?
    8 Dec 2001
    It says that length is 34 cm but it seems to me that the lighted are is a lot shorter. Neons are also quite dimm so I'm not sure how powerfull that effect would be... just a thought.
  4. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    That looks like a 15" tube to me. (What I bought in US)
    Here is a good image that should give you the scale it has compared to a case:
    (Mine are crackle lighting neon)
    Any my moding guide for these is here:
    http://www.zapwizard.com/lighting
  5. delphia
    9 Sep 2002
    yeah i remembered yours and i was kinda hoping these werent the same thing, although your mod was good its not the kinda thing i would build
  6. ZapWizard
    19 Sep 2002
    They are not the same thing, but they are the same size.
    Plus I am sure you can find the original car version cheaper.
