Modding Are these cable combs any good?
Discussion in 'Modding' started by CrapBag, 20 Feb 2015.
  1. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    These are the combs in question
    I want to tidy the PSU cables I have cut, shortened and sleeved with paracord and heat shrink sleeving.
    If anyone has used them before will the sleeved wires pass through the holes or would I be better off using the open ended type combs?
  2. Waynio
    Waynio Relaxing
    20 Aug 2009
    They are the neatist but you have to put them on while the end plugs aren't on the cables, the other open type are the ones you can put on easy after a sleeving job, not quite as good looking but do the same job with less hassle.
