Whenever I save images using photoshop and then open them in IE or FIrefox, all of the colors ae washed out and stuff, do you know how to fix this, because its really annoying me. Is there a difference between photoshop colors and IE colors.
thats because you are using some funky colour profile in photoshop. If everything is looking washed out its probally a super bright one that u might use for outdoor adverts or something. you can change them by going to edit >> colour settings
Use this on the images: http://www.herr-reinhard.de/media/files/pngcrush-gamma-0.2.zip (or you can just use pngcrush via command line or sth) It will fix the problem (by removing the gamma crap) and will also reduce the file size too.
