Case Mod - In Progress Artifact Project
Discussion in 'Project Logs' started by NemeziS, 11 Nov 2009.
  1. NemeziS
    NemeziS What's a Dremel?
    9 Oct 2009
    Hi from Russia!
    To introduce myself I want to show you my last case. I started up in October '08 and finished it about two weeks ago. I apologize about my English, got no experience for the long time. :worried:
    My comments to the pictures will be short. If someone got questions I try to give more detailed answer.
    Made alu-box 250*450*250mm
    Some plastic panels for backsides
    Macroflex foam
    Transparent 5mm acrylic for front sides. Got 2 "front sides" because the case will be turned with corner to me.
    Now first unusual material for modding - granulated plastic. It melts with t 180 Celsius.
    As you can see thin acrylic melts too:D
    Now we cut some lines in protect film with knife
    To fix this granulated thing before "cooking" I used this spray glue
    As result
    Protect film moved off
    Time for dinner:D
    15min and...
    first side...
    second one...
    Basecoating for the right inner lighting.
    Foil instead of scotch tape
    Self-cutted plastic puzzle
    Oh! I forgot about the configuration:
    M2N MX
    Athlon 64 4400+
    2*1024 DDR2 OCZ
    Asus 8800 GTS 320Mb
    Seagate 250Gb SATA
    Hyper 650W
    As you can see, all these plastic parts were mounted on double sided 3M tape
    More foam
    Cutted and filled
    Let's give some attention to PS and hard drive.
    Mount for PS
    For hard drive
    For backside
    The most interesting part of that case is the top
    DVD-Rom mounted vertically
    Some work with plastic
    Alabaster (gypsum)
    Second stage
    You see, white part is already dry and yellow - wet
    Here is process of making 3d symbols for PowerOn button
    :dremel:
    The hardest thing was to take them out from form.
    You can see small parts of wood before the polish work
    Glue, acrylic
    I will update this log soon.
  2. urbtree
    urbtree What's a Dremel?
    2 Oct 2006
    not really sure what your going for here but looking forward to see the results
  3. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Likewise - weird materials! I'm expecting black rock with green veins in it, if I know anything about lost/mysterious/powerful (delete as inappropriate) artifacts...
  4. NemeziS
    9 Oct 2009
    Update
    Part2
    More dremel work
    Lighting pads for symbols
    Now a small test.
    Charming, isn't it? :D
    Making of power buttons. Thin plastic, textile, glue.
    "Stealth" buttons ready
    Base painting with black waterbased acryl
    Backside. Looks ugly. Electric part is the weakest in my modding. :wallbash:
    Additional button for DVD-Rom opening
    Power for LEDs in symbols on top
    When I painted the top I noticed that the top and sides have different texture look. I needed to remake side panels :wallbash:
    Base painting for second time
    Backside panel with "grille"
    And then finish paint. Special 2-colour granite texture paint.
    Electric parts for coolers
    Making of fan-control button
    Some patience and sandpaper
    Non-painted stealth panel for DVD-Rom
    Now putting all together (I know about the mess :blush: )
    What can you say about painting? :thumb:
    Fan control at the left side
    I changed the button for dvd to a smaller one from mouse.
    It works! :clap:
  5. alecamused
    alecamused Minimodder
    22 Apr 2008
    thats insane... in a very good way.. :thumb:
  6. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    yupz +1
  7. NemeziS
    9 Oct 2009
    Tnx for comments
    Now final pics and video how all this works. Btw, is you push all 4 buttons PC doesn't start. Combination is 2-3-5 I mean fingers.:cooldude:
    Usb on front panel
    More details
    Case w/wo lighting
    Video
  8. bagman
    bagman Minimodder
    18 Apr 2009
    nice mod really like the glowing lights
    i also like the sort of volcanic theme you got going there looks ace
  9. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    Looks like some souped up stone from the "Fifth Element" movie
  10. stonedsurd
    11 Mar 2009
    Oh my GOD, that' just awesome! :jawdrop:
  11. Xion X2
    Xion X2 What's a Dremel?
    18 Oct 2009
    Nemesis, this is pretty damn cool, man. It reminds me of Stephen King's "The Tommyknockers."
    Very creative and original. I also like your idea about having to press certain combinations to turn the PC on.
    I have to admit, toward the beginning of the log I was thinking to myself that it looked like a kindergartner's first day in art class and laughed several times, but step by step you turned it into something that looks somewhat professional and very original. The granite paint that you used topped it off I think.
    Nice job!
  12. Colossous
    Colossous Minimodder
    28 May 2007
    Thats really different - great idea :thumb:
  13. Kumo
    Kumo What's a Dremel?
    18 Oct 2004
    Really nice project, dude! Love the buttons thing.
  14. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    that is, euhm, an awestone!
  15. sk8roy
    sk8roy What's a Dremel?
    12 Sep 2009
    Looks really cool, when I saw the first post I was wondering what the heck you were doing but now that I see the end it is amazing. One question though. The power switch is the four fingers on the top, do you have to press them in a certain order or certain ones at the same time to power it on? Like a secret combination? If so, that makes this mod even sweeter...
  16. NemeziS
    9 Oct 2009
    You must press 3 buttons at the same time but if you press with ring-finger combination doesn't work.
    Unfortunately I haven't enough soldering skill to make electric combination lock with a certain order :wallbash:
    Tnx to all for comments :thumb:
